Right Angle steam radiator vavles
Louie
Member Posts: 18
Guy's, I have a problem. I looked at a steam job that was
done in the early 1900's with supply valves that have 3/4 in
and 1/2 out to the radiator.
This is two pipe system. 28 of them and most of them are seized. Customer wants me to replace them all but I cant find any so far with that configuration.
Help! Thanks,
Louie
Help! Thanks,
Louie
check with Starbuck in mass.0 -
Try Tunstall
www.tunstall-inc.com . They say they can rebuild any valve. This would avoid the need to replace them all. Talk to Tom Tunstall and tell him I sent you.
That sounds like some sort of Vapor system- any names or other info on the valves or other hardware?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
