basement plumbing question
ross_2
ross_2 Member Posts: 1
Hi,
This is a straight-up plumbing question, not a heating question, so let me apologize up front. Whose bath fixtures (toilet/shower/lav) would you recommend for basement installation. I have seen different models made for basements (all designed pretty similarly, I think) and was just wondering if there was a preference.
Thanks!
ross
  • antman
    antman Member Posts: 182
    Kohler, American Standard, Eljer, Gerber
    Not necessarily in that order but to name a few.
    cost will be a factor.
    Stay away from the big box stores as they will be no help in making a selection, try a local PLUMBING SUPPLY house.
    Ant
  • Mike Kraft
    Mike Kraft Member Posts: 406
    Toilet of choice
    The Toto G-Max.Great 1.6 gallon flusher.Increased passage ways in the trapway and tank to bowl.As far as the rest your pick.For a nice shower base and wall tile try Jacuzzi acrylic or do a mud job and just get a quality strainer.Grohe makes a real nice tub/shower mix/volume control.Moen also has a nice selection.As stated above visit a good showroom.
    cheese
  • kevin
    kevin Member Posts: 420
    i think the basement bath is the key...
    are you asking about a toilet/plb. system that is for use below the sewer line ? Zoeller makes a good sew. ejt. package....I have used a macerating toilet combo w/o any problems but you have to be careful....hope this is what you meant....kpc
