basement plumbing question
ross_2
Member Posts: 1
Hi,
This is a straight-up plumbing question, not a heating question, so let me apologize up front. Whose bath fixtures (toilet/shower/lav) would you recommend for basement installation. I have seen different models made for basements (all designed pretty similarly, I think) and was just wondering if there was a preference.
Thanks!
ross
Thanks!
ross
Kohler, American Standard, Eljer, Gerber
Not necessarily in that order but to name a few.
cost will be a factor.
Stay away from the big box stores as they will be no help in making a selection, try a local PLUMBING SUPPLY house.
Ant
Toilet of choice
The Toto G-Max.Great 1.6 gallon flusher.Increased passage ways in the trapway and tank to bowl.As far as the rest your pick.For a nice shower base and wall tile try Jacuzzi acrylic or do a mud job and just get a quality strainer.Grohe makes a real nice tub/shower mix/volume control.Moen also has a nice selection.As stated above visit a good showroom.
cheese0 -
i think the basement bath is the key...
are you asking about a toilet/plb. system that is for use below the sewer line ? Zoeller makes a good sew. ejt. package....I have used a macerating toilet combo w/o any problems but you have to be careful....hope this is what you meant....kpc0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
