Acronyms - Dan H.
Duh
Must be getting old(er). CSST of course, corrugated stainless steel tubing. With todays post. Also we use tfmr for transformer and tsat for thermostat and might as well add rest of the relay contacts. DPDT and DPST. And ECO for energy cut off and PT for pressure temperature relief valve and SSOV for service shut off valve, honeywell has a lot of these terms for commercial gas trains. perhaps bill could give a list.0 -
How about
CAD - Computer Aided Design or (Ctrl+Alt+Delete)
CAE - Computer Aided Engineering
Terry H.0 -
Acronyms
Not exactly acronyms, but a great glossary of energy-related terms as well as acronyms is located at http://www.eere.energy.gov/consumerinfo/glossary.html0 -
CAD -- Certain Artistic Deficit
Sorry about that--it's the part of me that NEEDS to push a "real" pencil and CAD always makes me think of the stupid, hideously complex roofs that they make "easy."0 -
There's a thought
Maybe we should have a Hot Tech Topic that's a glossary of heating terms. Thanks for the inspiration, Mike.Retired and loving it.0 -
Formulas
As long as we're at it, we could have some basic formulas.
Siggy would LOVE us! Talk about being in Hog Heaven.
Senior Designer/Trainer
Precision Hydronics Corporation
www.precisionhydronics.com0 -
Plan Accronyms
CUH - cabinet unit heater
UH - Unit Heater
BBR - Baseboard Radiation
CUV - classroom unit ventilator
AHU - Air Handling Unit
Blr - Boiler
ERU - Energy Recovery Unit
HtX - Heat Exchanger
Conv - Convector
HP - Heat Pump
EF - Exhaust Fan
BFP - Backflow Preventer
PVB - Presure Vacumm Breaker
RPZ - Reduced Pressure Zone
HWS - Heating Water Supply
CWS - Chilled Water supply
HWR - Heating Water Return
LLS - Liguid Line Solinoid
HGPB - Hot Gas By Pass
UNLD - Unloader
EPR - Evaporator Pressure Regulator
CPR - Crankcase Pressure regulator
CCH - Crankcase Heater
EUH - Electric Unit Heater
DDC - Direct Digital Control
Pneu - Pneumatic
Frz - Freezestat
HL - High Limit
DA - Discharge Air
RA - Return Air
SA - Supply Air
RC - Reciever Controller
PE - Pneumatic / electric (switch)
EP - Electric / Pneumatic (valve)
TD - Time delay
HPCO - High Pressure Cut Out
LPCO - Low Pressure Cut Out
CO - Change Over (when used as control label)
LWCO - Low water cut off
FCU - Fan Coil Unit
RCP - Radient Ceiling Pannel
VAV - Variable Air Volume (box)
RTU - Rooftop Unit
HV - Heating & Ventilating (unit)
SOMeBODY STOP ME!!!!
believe it or not
this is real common in the us navy. its what gets written across a report that gets sent back for clarification...****-what the ****0 -
an all important one...........
RTFM:)
cheese0 -
UK acronyms
Some of these may only be used in the UK.
CHW = chilled water
TA = to above
TB = to below
FA = from above
FB = from below
CWDS = cold water down service (from a high-level storage tank)
PW = pressurized water
CWM = cold water main
LTHW = low temperature hot water (heating at less than 100degC)
MTHW = medium temperature hot water (heating at 100degC to 120degC)
HTHW = high temperature hot water (heating above 120 degC)
HWS = hot water service
PRV = pressure relief valve (i.e., safety valve), may also be used for a reducing valve
CIBSE = Chartered Institute of Building Services Engineers (UK equivalent of ASHRAE)
BSP = British Standard Pipe thread
DX = direct expansion cooling
RTM = read the manual
RTFM = Please, read the manual (Cheese got there first)
TBOE = top-and bottom, opposite ends (radiator connections)
BOE = bottom opposite ends (re radiator connections)
SWMBO = she who must be obeyed
IV = isolating valve
NC = normally closed (re valves)
NO = normally open (re valves)
SC = stop-cock
DC = drain cock
AV = air vent
AAV = automatic air vent
CS = commissioning station/set (flow measuring device & double regulating valve)
FMD = flow measuring device
DRV = double regulating valve
MV = motorized valve
HL = high level
LL = low level
NRV = non-return valve (check valve)
PG = pressure gauge
BS = British Standards Institute
Pa = Pascal ( SI unit of pressure)
PU = pressurization unit
LPG = liquid petroleum gas, liquid propane gas (Im not sure which one is correct)
NG = natural gas
CA = compressed air
SG = spheroidal graphite (cast iron)
SG = sight glass
SG = specific gravity
DZR = de-zincification resistant (corrosion resistant brass)
DA = direct acting (re control valves)
RA = reverse acting (re control valves)
PID = proportional, integral & differential controller
PI = proportional & integral controller
FD = fire damper
MS =mild steel
SD = smoke detector
MEG = mono-ethylene glycol (anti-freeze)
BMS = Building Management System/DDC
BER = beyond economic repair
TRV = thermostatic radiator valve
OSA = Or Similar and Approved
TS = Temperature Sensor0 -
Dan...
Has anybody mentioned "TLDMN"
How many Years ago was it you wrote the artical about that? I still think of that everytime somebody hands me a buisness card with a bunch of letters after their name.
HYK
(Hug Your Kids)
Tom0 -
I was once....
told by my wife the most important letters after my name were "and Carol.." (When we're listed "Tom and Carol Meyer".)
"Sweet Carol" has some unique insight at times.
The most important one to HeatingHelp.com
T.L.M.
Figured we better not forget this one.
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
