Acronyms - Dan H.
2»
  • Dale
    Dale Member Posts: 1,317
    Duh
    Must be getting old(er). CSST of course, corrugated stainless steel tubing. With todays post. Also we use tfmr for transformer and tsat for thermostat and might as well add rest of the relay contacts. DPDT and DPST. And ECO for energy cut off and PT for pressure temperature relief valve and SSOV for service shut off valve, honeywell has a lot of these terms for commercial gas trains. perhaps bill could give a list.
  • Terry H.
    Terry H. Member Posts: 73
    How about
    CAD - Computer Aided Design or (Ctrl+Alt+Delete)
    CAE - Computer Aided Engineering
    Terry H.
  • Mike S. GasNetworks
    Mike S. GasNetworks Member Posts: 42
    Acronyms
    Not exactly acronyms, but a great glossary of energy-related terms as well as acronyms is located at http://www.eere.energy.gov/consumerinfo/glossary.html
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    CAD -- Certain Artistic Deficit
    Sorry about that--it's the part of me that NEEDS to push a "real" pencil and CAD always makes me think of the stupid, hideously complex roofs that they make "easy."
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,727
    There's a thought
    Maybe we should have a Hot Tech Topic that's a glossary of heating terms. Thanks for the inspiration, Mike.
    Retired and loving it.
  • Tom Meyer
    Tom Meyer Member Posts: 300
    Formulas
    As long as we're at it, we could have some basic formulas.
    Siggy would LOVE us! Talk about being in Hog Heaven.
    Senior Designer/Trainer
    Precision Hydronics Corporation
    www.precisionhydronics.com
  • Dan Law_3
    Dan Law_3 Member Posts: 7
    Plan Accronyms
    CUH - cabinet unit heater
    UH - Unit Heater
    BBR - Baseboard Radiation
    CUV - classroom unit ventilator
    AHU - Air Handling Unit
    Blr - Boiler
    ERU - Energy Recovery Unit
    HtX - Heat Exchanger
    Conv - Convector
    HP - Heat Pump
    EF - Exhaust Fan
    BFP - Backflow Preventer
    PVB - Presure Vacumm Breaker
    RPZ - Reduced Pressure Zone
    HWS - Heating Water Supply
    CWS - Chilled Water supply
    HWR - Heating Water Return
    LLS - Liguid Line Solinoid
    HGPB - Hot Gas By Pass
    UNLD - Unloader
    EPR - Evaporator Pressure Regulator
    CPR - Crankcase Pressure regulator
    CCH - Crankcase Heater
    EUH - Electric Unit Heater
    DDC - Direct Digital Control
    Pneu - Pneumatic
    Frz - Freezestat
    HL - High Limit
    DA - Discharge Air
    RA - Return Air
    SA - Supply Air
    RC - Reciever Controller
    PE - Pneumatic / electric (switch)
    EP - Electric / Pneumatic (valve)
    TD - Time delay
    HPCO - High Pressure Cut Out
    LPCO - Low Pressure Cut Out
    CO - Change Over (when used as control label)
    LWCO - Low water cut off
    FCU - Fan Coil Unit
    RCP - Radient Ceiling Pannel
    VAV - Variable Air Volume (box)
    RTU - Rooftop Unit
    HV - Heating & Ventilating (unit)
    SOMeBODY STOP ME!!!!
  • Dan Law_3
  • believe it or not
    this is real common in the us navy. its what gets written across a report that gets sent back for clarification...****-what the ****
  • Mike Kraft
    Mike Kraft Member Posts: 406
    an all important one...........
    RTFM:)
    cheese
  • Aidan (UK)
    Aidan (UK) Member Posts: 290
    UK acronyms
    Some of these may only be used in the UK.
    CHW = chilled water
    TA = to above
    TB = to below
    FA = from above
    FB = from below
    CWDS = cold water down service (from a high-level storage tank)
    PW = pressurized water
    CWM = cold water main
    LTHW = low temperature hot water (heating at less than 100degC)
    MTHW = medium temperature hot water (heating at 100degC to 120degC)
    HTHW = high temperature hot water (heating above 120 degC)
    HWS = hot water service
    PRV = pressure relief valve (i.e., safety valve), may also be used for a reducing valve
    CIBSE = Chartered Institute of Building Services Engineers (UK equivalent of ASHRAE)
    BSP = British Standard Pipe thread
    DX = direct expansion cooling
    RTM = read the manual
    RTFM = Please, read the manual (Cheese got there first)
    TBOE = top-and bottom, opposite ends (radiator connections)
    BOE = bottom opposite ends (re radiator connections)
    SWMBO = she who must be obeyed
    IV = isolating valve
    NC = normally closed (re valves)
    NO = normally open (re valves)
    SC = stop-cock
    DC = drain cock
    AV = air vent
    AAV = automatic air vent
    CS = commissioning station/set (flow measuring device & double regulating valve)
    FMD = flow measuring device
    DRV = double regulating valve
    MV = motorized valve
    HL = high level
    LL = low level
    NRV = non-return valve (check valve)
    PG = pressure gauge
    BS = British Standards Institute
    Pa = Pascal ( SI unit of pressure)
    PU = pressurization unit
    LPG = liquid petroleum gas, liquid propane gas (I’m not sure which one is correct)
    NG = natural gas
    CA = compressed air
    SG = spheroidal graphite (cast iron)
    SG = sight glass
    SG = specific gravity
    DZR = de-zincification resistant (corrosion resistant brass)
    DA = direct acting (re control valves)
    RA = reverse acting (re control valves)
    PID = proportional, integral & differential controller
    PI = proportional & integral controller
    FD = fire damper
    MS =mild steel
    SD = smoke detector
    MEG = mono-ethylene glycol (anti-freeze)
    BMS = Building Management System/DDC
    BER = beyond economic repair
    TRV = thermostatic radiator valve
    OSA = Or Similar and Approved
    TS = Temperature Sensor
  • TLS_4
    TLS_4 Member Posts: 1
    Dan...
    Has anybody mentioned "TLDMN"
    How many Years ago was it you wrote the artical about that? I still think of that everytime somebody hands me a buisness card with a bunch of letters after their name.
    HYK
    (Hug Your Kids)
    Tom
  • Tom Meyer
    I was once....
    told by my wife the most important letters after my name were "and Carol.." (When we're listed "Tom and Carol Meyer".)
    "Sweet Carol" has some unique insight at times.
  • Glenn Harrison
    Glenn Harrison Member Posts: 405
    The most important one to HeatingHelp.com
    T.L.M.
    Figured we better not forget this one. ;)
