Acronyms - Dan H.
PJO_2
Member Posts: 36
with acronyms...Q = V A
Q=Flow
V=Velocity
A=Area
Manipulation means you can solve for anything given the other two...
This is used quite often I suspect :-)
Q=Flow
V=Velocity
A=Area
Tom Meyer suggested
that we have a place on the site where we could list common industry acronyms, such as SWP and WOG. These often confuse people and I think it's a good idea. Hot Tech Topics would be the perfect place for this.
I could use some help, though. When you have a chance, please email me any acronyms you can think of. I'll compile them and put them in alphabetical order in Hot Tech Topics. Thanks.Retired and loving it.0 -
C'mon, lads!
Help me out here.Retired and loving it.0 -
From the Land of Steam
"A" Dimension= distance water will rise in the drip at the end of the steam main, when there IS left-over steam pressure at the drip
"B" Dimension= distance water will rise in the drip at the end of the steam main, when there is NO left-over steam pressure at the drip (pressure blocked by a trap, water seal, orifice or motorized valve)
BTU- British Thermal Unit, the amount of heat needed to raise 1 pound of water (roughly 1 pint) by 1 degree Fahrenheit.
BTUH- amount of BTUs needed per hour.
EDR= heat output, equivalent direct radiation, measured in square feet. Actual output will vary according to what is being circulated thru the radiator.
LWCO= low water cutoff
MBH- heat input or output, 1,000 BTU per hour. M was used because it is the Roman numeral for 1,000.
Pressure and Flow:
CFH= air or gas flow, cubic feet per hour
CFM= air or gas flow, cubic feet per minute
GPH= liquid flow, gallons per hour, as used on oil burner nozzles and fuel units
GPM= liquid flow, gallons per minute, as used on many types of pumps
PSI= pressure, pounds per square inch, usually "gauge"
PSIA= pressure, pounds per square inch, absolute (disregarding atmospheric pressure)
PSIG= presure, pounds per square inch, gauge (where zero on the gauge is atmospheric pressure)
Boiler Ratings:
Input= amount of heat produced at the burner. Rating is GPH on oil boilers and MBH on gas units.
DOE Heating Capacity or Gross Output= amount of heat delivered to the outlet pipe of the boiler.
Net (or IBR)= amount of heat available at the radiators, after deducting the pick-up factor (heat needed to warm the pipes). This is the rating you use to match the boiler's capacity to the heating load.
AFUE= annual fuel utilization efficiency, a measure of fuel in to heat out over the course of a typical heating season, including any off-cycle losses. Roughly equivalent to Miles per Gallon on a car.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Baltimore, MD, USA
Consulting0 -
Good stuff
Thanks. I'm building the list in Hot Tech Topics under the subject, "Industry Acronymns" Check it out.Retired and loving it.0 -
FUBAR
should go in there somewhere, huh?
Before
or after the job? :-0Retired and loving it.0 -
Looking Good
If I might suggest- we should do as good a job as we can to define what these terms mean, for example "BTU- amount of heat needed to raise the temperature of 1 pound of water 1 degree Fahrenheit". This will be a big help to all the budding Wetheads who will use the list!
Consulting0 -
This may be last on list \"Z\" dimension
"z" dimension = setback of nozzle on beckett burners.
"t" gauge = gauge used to set "z" dimension.
AGA= American Gas Association
CGA= Canadian Gas Association
ASME= American Society of Mechanical Engineers
IBR = Institute of Boiler and Radiator Manufacturers
UL = Underwriters Laboratories
CYA = cover your a~~
John@Reliable0 -
Beckett has a \"Z\" gauge, now
It can be used without pulling the burner out. It fits over the end of the drawer assy and even has a notch to set the electrodes.
You put the gauge on the end, fit it in and adjust the "Z" dimension, then lock it in and pull out the drawer assy. Remove the gauge, and reassemble. Ask for it where you buy your burners.
Noel0 -
Some more
A.S.M.E. (Always, Sometimes, Maybe, Except, or A Substantial Monetary Exchange, or American Society of Mechanical Engineers.
N.P.S.H. (not pumping so hot)
N.F.P.A. National Fire Prtoection Admin.
N.S.F. (No so fast) National Sanitation Foundation
B.O.C.A. Building Officials Conference Assoc.
S.B.O.C.A. Southern Building Officials Conference Assoc.
I.A.P.M.O. Int'l Association of Plumbing/Mechanical Officianados.
U.P.C. Uniform Plumbing Code
U.E.C. Uniform Electircal Code
U.M.C. Universal Mehcanical Code
P.I.T.A. (Pain in the @$$)
C.Y.A. (Cover Your @$$)
W.A.G. (Wild @$$ guess)
S.W.A.G. Scientific wild @$$ guess
A.N.S.I. (Ain't nothin' so insignificant) American National Standards Institute.
C.S.A. Canadian Standards Institute
H.U.D. Housing/Urban Development
I.C.B.O. Internat'l Conference of Building Officials
PEX
PEX-AL-PEX
PE-AL-PE
EVOH
ME0 -
Beckett \"z\" gauge = Kit # Z2000
John@Reliable0 -
How about
ASPE American Society of Plumbing Engineers
CIPE Certified in Plumbing Engineering
CPD Certified in Plumbing Design
I realize it's plumbing but we deal with a LOT of water.
Jack
CPD
One more: how about the KISS principle.0 -
Delta's
Delta t Delta P, etc?
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Dan just faxed
you four pages of acronyms!!!0 -
acronyms
Dan, How about NAOHSM !!!!!!!! More guys should now about this one....see you there next week.
Al
how about
these which i have seen more in regards to federal/military work..
IAW-in accordance with (usually used regarding specifications)
SOV-shut off valve
COV-cut out valve
AFFF-aqueous film forming foam
TYP-typical0 -
heres more
http://www.edwardvalves.com/pdf/catalogs/vogt/V134.pdf
dont forget cwp- cold water pressure..that one came up on one of our jobs this year and caused all kinds of arguing till i found it on the web.0 -
and these
O2-oxygen, CO2-carbon dioxide, CO-carbon monoxide etc.0 -
Acronyms
U Factor - the symbol representing the heat flow through various combinations of building materials.
UV - Ultraviolet
ATC - Automatic Temperature Control
C Factor - the amount of heat, in BTU, conducted through one square foot of a material of a specified thickness, per hour, per degree temperature difference.
COP - Coefficient of performance
DD - Degree day
DDC - Direct Digital Control
DP - Double pole
DPC - Diffferential pressure control
DX - Direct expansion
EER - Energy efficiency ratio
emf - electromotive force; voltage
FLA - Full load amperage, the current draw of a motor under full load.
HSPF - Heating system (or seasonal) performance factor
IAQ - Indoor air quality
ID - inside diameter
IR drop - Voltage drop or loss; equal to amperage (I) times resistance (R)
ipt - Iron pipe thread
K factor - the ability of a material to conduct heat; expressed in BTU per hour, per square foot, per inch of thickness of the material.
kVa - Kilovolt ampere: the unit of electrical flow that is equal to volts multiplied by amperes and divided by 1000.
kWh - Kilowatt-hour: the consumption of one thousand watts per hour.
kW - Kilowatt: one thousand watts
LPC - Low pressure control
LPG - Liquified petroleum gas
LRA - Locked rotor amperage
MBH - thousands of Btu; (ex. 82MBH = 82,000 Btu)
NC - National coarse thread
NF - National fine thread
NPT - National pipe thread
NC - Normally closed; a switch contact that is closed until operated or energized.
NO - Normally open; a switch contact that is open until operated or energized.
OD - Outside diameter
OEM - Original equipment manufacturer
ppm - parts per million
PSC - permanent split capacitor
psi - pounds per square inch
psia - pounds per square inch, absolute; atmospheric pressure measured by the height of the column of mercury or water that it supports.
psig - pounds per square inch, gauge; pressure measured on a manometer (gauge).
PVC - polyvinyl chloride
R - thermal resistance; refrigerant; Rankine
rpm - revolutions per minute
SBS - Sick building syndrome
SEER - seasonal energy efficiency ratio; a measurement of cooling capacity.
SCR - silicon controlled rectifier
SI system - the metric system
SPDT - single-pole, double throw; a swtich with one movable contact and two stationary contacts.
SPST - single-pole, single throw; a switch with one movable contact and one stationary contact.
TAB - Testing, adjusting, balancing
TD - Temperature difference (also known as Delta T)
THI - temperature-humidity index; a scale that combines dry bulb and wet bulb temperatures to estimate human comfort.
Senior Designer/Trainer
Precision Hydronics Corporation
www.precisionhydronics.com0 -
Don't forget
BOHICA (Bend over, here it comes again)0 -
Getting big!
Check it out:
http://www.heatinghelp.com/newsletter.cfm?Id=136
And I still have to add the four pages from Timmie.
Thanks, guys. I've got a feeling this is going to help a lot of people.Retired and loving it.0 -
and also
ph- regading the acidity index0 -
yet more
these can hurt if missed on the plans.......
MT-magnetic particle test,,UT-ultrasonic test,,RT-radiographic test...how about EPDM-ethylene propylene dimonomer..0 -
Noted
and added. Thanks, Gerry!Retired and loving it.0 -
Great
idea ,this will be very helpful to the up and comers such as myself.0 -
Billy,
I'm working for YOU. Lots of people taught me (and are still teaching me), and lots of people will teach you. I'm just happy to be a brick in the Wall, pal.
Thanks for being here.Retired and loving it.0 -
acros
ET eddy current testing. Those eddy current guys say it works? I took the course....a bizarre science! A bit like economics? George Bernard Shaw once said, " If you take all the economists in the world and align them end to end...they'll never reach a conclusion. Sry ET techs!
NFG....No F---- Good
SOOL .......out of luck
FOB..free on board. If we drop it you need a lawyer.
SCRWGEE...not working.
;-)0 -
Billy, the up and comer!
You need to get this if you don't already have one and it's free! Burnham boilers 4x6 book "Burnham Heating Helper" has so much useful information, check it out. Also some great books here too "Books and more".John@Reliable0 -
A few more...
abs - absolute
atm - atmosphere
bp - boiling point
cfm - cubic feet per minute
cfs - cubic feet per second
fpm - feet per minute
fp - freezing point
ft-lb - foot pound
hp - horsepower
hp-hr - horsepower per hour
in-lb - inch pound
rps - revolutions per second
sp gr - specific gravity
sp ht - specific heat
v - volt
whr - watt hour
A bunch from John Gates \"Just for Tech's\" site.
http://www.jcgbs.com/users/jft/internet.htm
See if there are any there that were not listed already.0 -
how 'bout...
BFH........I use it to bust up those old cast iron relic's0 -
How about
MPT = Male pipe thread
FPT = Female pipe thread
NC = National course, a measure of the number of threads on a fastener, measured in threads per inch. ie; 1/2 x 13, a 1/2" bolt with 13 threads per inch.
NF = National fine 1/2 x 20, 1/2 bolt 20 threads per inch
and all the metric equalivalants.
tpi = threads per inch
The Wild are not doing so good tonight.0 -
Don't forget
POS - a boiler poorly installed or maintained, or running beyond it's expected useful lifespan.
TLA- Three Letter Acronym0 -
AFMA (A Few More Acronyms)
HEAT - High Explosive Anti-Tank
BEER - Beginning Enjoy, Ending Regret
ADIDAS - All Day I Dream About Sex
HSOA - Help Stamp Out Acronyms
CPA - Coffee Pot Attendant
RTHM - Read The Helpful Manual
YMHMYFAIOA - You May Have Mistaken Yourself For An Inventor Of Acronyms0 -
acron.
AIM = Alcohol Induced Maintainence
AFF. Above Finished Floor
TXV = Thermal expansion valve [aka TEV]0 -
My Personnal Favorite
NIC - Not in contract
Has anyone posted PONPC ?
Scott "CH" Milne
Couple I forgot from my e-mail
and don't see here yet.
CV -- Don't know the acronym gpm through a valve or similar device to induce a delta-p of 1 psi. (Amazing how much we use acronyms isn't it!)
PPPPP -- Proper Planning Prevents Pi$$-poor Performance0 -
Not a bad list
for less than 24 hours. Thanks! Keep 'em coming as you think of them.Retired and loving it.0 -
DILLIGAS
Since John Hall suggested BOHICA, I need to add Dilligas - Do I Look Like I Give A S(omething).
Sorry, but I had to....0 -
How about an obvious one?
RPA - Radiant Panel Association
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
- 19 Recall Announcements
