Acronyms - Dan H.
PJO_2
PJO_2 Member Posts: 36
with acronyms...Q = V A
Q=Flow
V=Velocity
A=Area
Manipulation means you can solve for anything given the other two...
This is used quite often I suspect :-)
«1
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,546
    Tom Meyer suggested
    that we have a place on the site where we could list common industry acronyms, such as SWP and WOG. These often confuse people and I think it's a good idea. Hot Tech Topics would be the perfect place for this.
    I could use some help, though. When you have a chance, please email me any acronyms you can think of. I'll compile them and put them in alphabetical order in Hot Tech Topics. Thanks.
    Retired and loving it.
  • DanHolohan
    C'mon, lads!
    Help me out here.
    Steamhead Member Posts: 16,901
    From the Land of Steam
    "A" Dimension= distance water will rise in the drip at the end of the steam main, when there IS left-over steam pressure at the drip
    "B" Dimension= distance water will rise in the drip at the end of the steam main, when there is NO left-over steam pressure at the drip (pressure blocked by a trap, water seal, orifice or motorized valve)
    BTU- British Thermal Unit, the amount of heat needed to raise 1 pound of water (roughly 1 pint) by 1 degree Fahrenheit.
    BTUH- amount of BTUs needed per hour.
    EDR= heat output, equivalent direct radiation, measured in square feet. Actual output will vary according to what is being circulated thru the radiator.
    LWCO= low water cutoff
    MBH- heat input or output, 1,000 BTU per hour. M was used because it is the Roman numeral for 1,000.
    Pressure and Flow:
    CFH= air or gas flow, cubic feet per hour
    CFM= air or gas flow, cubic feet per minute
    GPH= liquid flow, gallons per hour, as used on oil burner nozzles and fuel units
    GPM= liquid flow, gallons per minute, as used on many types of pumps
    PSI= pressure, pounds per square inch, usually "gauge"
    PSIA= pressure, pounds per square inch, absolute (disregarding atmospheric pressure)
    PSIG= presure, pounds per square inch, gauge (where zero on the gauge is atmospheric pressure)
    Boiler Ratings:
    Input= amount of heat produced at the burner. Rating is GPH on oil boilers and MBH on gas units.
    DOE Heating Capacity or Gross Output= amount of heat delivered to the outlet pipe of the boiler.
    Net (or IBR)= amount of heat available at the radiators, after deducting the pick-up factor (heat needed to warm the pipes). This is the rating you use to match the boiler's capacity to the heating load.
    AFUE= annual fuel utilization efficiency, a measure of fuel in to heat out over the course of a typical heating season, including any off-cycle losses. Roughly equivalent to Miles per Gallon on a car.
    Consulting
  • DanHolohan
    Good stuff
    Thanks. I'm building the list in Hot Tech Topics under the subject, "Industry Acronymns" Check it out.
  • DanHolohan
    Before
    or after the job? :-0
    Looking Good
    If I might suggest- we should do as good a job as we can to define what these terms mean, for example "BTU- amount of heat needed to raise the temperature of 1 pound of water 1 degree Fahrenheit". This will be a big help to all the budding Wetheads who will use the list!
    Consulting
  • John@Reliable_2
    John@Reliable_2 Member Posts: 104
    This may be last on list \"Z\" dimension
    "z" dimension = setback of nozzle on beckett burners.
    "t" gauge = gauge used to set "z" dimension.
    AGA= American Gas Association
    CGA= Canadian Gas Association
    ASME= American Society of Mechanical Engineers
    IBR = Institute of Boiler and Radiator Manufacturers
    UL = Underwriters Laboratories
    CYA = cover your a~~
    John@Reliable
  • Unknown
    Unknown Member
    Beckett has a \"Z\" gauge, now
    It can be used without pulling the burner out. It fits over the end of the drawer assy and even has a notch to set the electrodes.
    You put the gauge on the end, fit it in and adjust the "Z" dimension, then lock it in and pull out the drawer assy. Remove the gauge, and reassemble. Ask for it where you buy your burners.
    Noel
  • [Deleted User]
    Some more
    A.S.M.E. (Always, Sometimes, Maybe, Except, or A Substantial Monetary Exchange, or American Society of Mechanical Engineers.
    N.P.S.H. (not pumping so hot)
    N.F.P.A. National Fire Prtoection Admin.
    N.S.F. (No so fast) National Sanitation Foundation
    B.O.C.A. Building Officials Conference Assoc.
    S.B.O.C.A. Southern Building Officials Conference Assoc.
    I.A.P.M.O. Int'l Association of Plumbing/Mechanical Officianados.
    U.P.C. Uniform Plumbing Code
    U.E.C. Uniform Electircal Code
    U.M.C. Universal Mehcanical Code
    P.I.T.A. (Pain in the @$$)
    C.Y.A. (Cover Your @$$)
    W.A.G. (Wild @$$ guess)
    S.W.A.G. Scientific wild @$$ guess
    A.N.S.I. (Ain't nothin' so insignificant) American National Standards Institute.
    C.S.A. Canadian Standards Institute
    H.U.D. Housing/Urban Development
    I.C.B.O. Internat'l Conference of Building Officials
    PEX
    PEX-AL-PEX
    PE-AL-PE
    EVOH
    ME
  • John@Reliable_2
    Beckett \"z\" gauge = Kit # Z2000
    John@Reliable
  • Jackchips
    Jackchips Member Posts: 344
    How about
    ASPE American Society of Plumbing Engineers
    CIPE Certified in Plumbing Engineering
    CPD Certified in Plumbing Design
    I realize it's plumbing but we deal with a LOT of water.
    Jack
    CPD
    One more: how about the KISS principle.
    hot_rod Member Posts: 22,261
  • Unknown
    Dan just faxed
    you four pages of acronyms!!!
  • Al Letellier
    Al Letellier Member Posts: 781
    acronyms
    Dan, How about NAOHSM !!!!!!!! More guys should now about this one....see you there next week.
    Al
  • [Deleted User]
    how about
    these which i have seen more in regards to federal/military work..
    IAW-in accordance with (usually used regarding specifications)
    SOV-shut off valve
    COV-cut out valve
    AFFF-aqueous film forming foam
    TYP-typical
  • [Deleted User]
    heres more
    http://www.edwardvalves.com/pdf/catalogs/vogt/V134.pdf
    dont forget cwp- cold water pressure..that one came up on one of our jobs this year and caused all kinds of arguing till i found it on the web.
  • [Deleted User]
    and these
    O2-oxygen, CO2-carbon dioxide, CO-carbon monoxide etc.
  • Tom Meyer
    Tom Meyer Member Posts: 300
    Acronyms
    U Factor - the symbol representing the heat flow through various combinations of building materials.
    UV - Ultraviolet
    ATC - Automatic Temperature Control
    C Factor - the amount of heat, in BTU, conducted through one square foot of a material of a specified thickness, per hour, per degree temperature difference.
    COP - Coefficient of performance
    DD - Degree day
    DDC - Direct Digital Control
    DP - Double pole
    DPC - Diffferential pressure control
    DX - Direct expansion
    EER - Energy efficiency ratio
    emf - electromotive force; voltage
    FLA - Full load amperage, the current draw of a motor under full load.
    HSPF - Heating system (or seasonal) performance factor
    IAQ - Indoor air quality
    ID - inside diameter
    IR drop - Voltage drop or loss; equal to amperage (I) times resistance (R)
    ipt - Iron pipe thread
    K factor - the ability of a material to conduct heat; expressed in BTU per hour, per square foot, per inch of thickness of the material.
    kVa - Kilovolt ampere: the unit of electrical flow that is equal to volts multiplied by amperes and divided by 1000.
    kWh - Kilowatt-hour: the consumption of one thousand watts per hour.
    kW - Kilowatt: one thousand watts
    LPC - Low pressure control
    LPG - Liquified petroleum gas
    LRA - Locked rotor amperage
    MBH - thousands of Btu; (ex. 82MBH = 82,000 Btu)
    NC - National coarse thread
    NF - National fine thread
    NPT - National pipe thread
    NC - Normally closed; a switch contact that is closed until operated or energized.
    NO - Normally open; a switch contact that is open until operated or energized.
    OD - Outside diameter
    OEM - Original equipment manufacturer
    ppm - parts per million
    PSC - permanent split capacitor
    psi - pounds per square inch
    psia - pounds per square inch, absolute; atmospheric pressure measured by the height of the column of mercury or water that it supports.
    psig - pounds per square inch, gauge; pressure measured on a manometer (gauge).
    PVC - polyvinyl chloride
    R - thermal resistance; refrigerant; Rankine
    rpm - revolutions per minute
    SBS - Sick building syndrome
    SEER - seasonal energy efficiency ratio; a measurement of cooling capacity.
    SCR - silicon controlled rectifier
    SI system - the metric system
    SPDT - single-pole, double throw; a swtich with one movable contact and two stationary contacts.
    SPST - single-pole, single throw; a switch with one movable contact and one stationary contact.
    TAB - Testing, adjusting, balancing
    TD - Temperature difference (also known as Delta T)
    THI - temperature-humidity index; a scale that combines dry bulb and wet bulb temperatures to estimate human comfort.
    Senior Designer/Trainer
    Precision Hydronics Corporation
    www.precisionhydronics.com
  • John R. Hall
    John R. Hall Member Posts: 2,246
    Don't forget
    BOHICA (Bend over, here it comes again)
  • DanHolohan
    Getting big!
    Check it out:
    http://www.heatinghelp.com/newsletter.cfm?Id=136
    And I still have to add the four pages from Timmie.
    Thanks, guys. I've got a feeling this is going to help a lot of people.
  • [Deleted User]
    and also
    ph- regading the acidity index
  • [Deleted User]
    yet more
    these can hurt if missed on the plans.......
    MT-magnetic particle test,,UT-ultrasonic test,,RT-radiographic test...how about EPDM-ethylene propylene dimonomer..
  • DanHolohan
    Noted
    and added. Thanks, Gerry!
  • joe_6
    joe_6 Member Posts: 23
    Great
    idea ,this will be very helpful to the up and comers such as myself.
  • DanHolohan
    Billy,
    I'm working for YOU. Lots of people taught me (and are still teaching me), and lots of people will teach you. I'm just happy to be a brick in the Wall, pal.
    Thanks for being here.
  • canuckDale
    canuckDale Member Posts: 77
    acros
    ET eddy current testing. Those eddy current guys say it works? I took the course....a bizarre science! A bit like economics? George Bernard Shaw once said, " If you take all the economists in the world and align them end to end...they'll never reach a conclusion. Sry ET techs!
    NFG....No F---- Good
    SOOL .......out of luck
    FOB..free on board. If we drop it you need a lawyer.
    SCRWGEE...not working.
  • John@Reliable_2
    Billy, the up and comer!
    You need to get this if you don't already have one and it's free! Burnham boilers 4x6 book "Burnham Heating Helper" has so much useful information, check it out. Also some great books here too "Books and more".John@Reliable
  • Tom Meyer
    A few more...
    abs - absolute
    atm - atmosphere
    bp - boiling point
    cfm - cubic feet per minute
    cfs - cubic feet per second
    fpm - feet per minute
    fp - freezing point
    ft-lb - foot pound
    hp - horsepower
    hp-hr - horsepower per hour
    in-lb - inch pound
    rps - revolutions per second
    sp gr - specific gravity
    sp ht - specific heat
    v - volt
    whr - watt hour
  • Glenn Harrison
    Glenn Harrison Member Posts: 405
    A bunch from John Gates \"Just for Tech's\" site.
    http://www.jcgbs.com/users/jft/internet.htm
    See if there are any there that were not listed already.
  • Floyd_3
    Floyd_3 Member Posts: 32
    how 'bout...
    BFH........I use it to bust up those old cast iron relic's
  • Wayne_12
    Wayne_12 Member Posts: 62
    How about
    MPT = Male pipe thread
    FPT = Female pipe thread
    NC = National course, a measure of the number of threads on a fastener, measured in threads per inch. ie; 1/2 x 13, a 1/2" bolt with 13 threads per inch.
    NF = National fine 1/2 x 20, 1/2 bolt 20 threads per inch
    and all the metric equalivalants.
    tpi = threads per inch
    The Wild are not doing so good tonight.
  • Tom M.
    Tom M. Member Posts: 237
    Don't forget
    POS - a boiler poorly installed or maintained, or running beyond it's expected useful lifespan.
    TLA- Three Letter Acronym
  • Paul Cooke
    Paul Cooke Member Posts: 181
    AFMA (A Few More Acronyms)
    HEAT - High Explosive Anti-Tank
    BEER - Beginning Enjoy, Ending Regret
    ADIDAS - All Day I Dream About Sex
    HSOA - Help Stamp Out Acronyms
    CPA - Coffee Pot Attendant
    RTHM - Read The Helpful Manual
    YMHMYFAIOA - You May Have Mistaken Yourself For An Inventor Of Acronyms
  • Bill NTSG
    Bill NTSG Member Posts: 321
    acron.
    AIM = Alcohol Induced Maintainence
    AFF. Above Finished Floor
    TXV = Thermal expansion valve [aka TEV]
  • ScottMP
    ScottMP Member Posts: 5,884
    My Personnal Favorite
    NIC - Not in contract
    Has anyone posted PONPC ?
    Scott "CH" Milne
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Couple I forgot from my e-mail
    and don't see here yet.
    CV -- Don't know the acronym gpm through a valve or similar device to induce a delta-p of 1 psi. (Amazing how much we use acronyms isn't it!)
    PPPPP -- Proper Planning Prevents Pi$$-poor Performance
  • DanHolohan
    Not a bad list
    for less than 24 hours. Thanks! Keep 'em coming as you think of them.
  • Jeff Lawrence_13
    Jeff Lawrence_13 Member Posts: 5
    DILLIGAS
    Since John Hall suggested BOHICA, I need to add Dilligas - Do I Look Like I Give A S(omething).
    Sorry, but I had to....
  • Tom Meyer
    How about an obvious one?
    RPA - Radiant Panel Association
