Water feed for 1 pipe steam
will smith
Member Posts: 4
Is there an absolute best location for tying in the fresh water makeup on a 1 pipe steam system (such as in the wet return near the boiler, or at a tee right at the boiler return)?
fresh water feed for 1 pipe steam
Is there an absolute best location for tying in the fresh water makeup on a 1 pipe steam system (such as in the wet return near the boiler, or at a tee right at the boiler return)?0 -
I like to tie them in
to the wet return prior to the Hartford Loop. This helps keep from shocking the boiler with cold water.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
I'm with Steamhead
absolutely.
Noel0 -
tie-in
Many thanks, Gents!0
- 120 Geothermal
