Water feed for 1 pipe steam
will smith
Is there an absolute best location for tying in the fresh water makeup on a 1 pipe steam system (such as in the wet return near the boiler, or at a tee right at the boiler return)?
fresh water feed for 1 pipe steam
Is there an absolute best location for tying in the fresh water makeup on a 1 pipe steam system (such as in the wet return near the boiler, or at a tee right at the boiler return)?0 -
I like to tie them in
to the wet return prior to the Hartford Loop. This helps keep from shocking the boiler with cold water.
I'm with Steamhead
absolutely.
Noel0 -
tie-in
Many thanks, Gents!0
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
