Thremo-Shocking ?
wazy
wazy Member Posts: 3
Who can hold better in the testing of Cast or Copper?
with return water @ 90 deg.
With a supply of 145 deg.
Cause where I work, now for 1 2/3 yrs , Slant-Fin hot water tanks keep failing
The only answer to this problem, as far as I can see is to operate both tanks at 140 deg. with constent 3 way mixing valve {supply,return,makup}
an expansion tank would help, The City of Rochester NY, said that Your system is pressuering there Mains?
any help thx?:
  • jim f
    jim f Member Posts: 182
    dont understand what you mean "The City of Rochester NY, said that Your system is pressuering there Mains? "
  • keith
    keith Member Posts: 224
    not sure what you mean
    what model slant fin? How are they failing? Is thermal expansion creeping back into the domestic water mains? A back flow preventor with double check valve and a thermal expansion tank would stop that problem.
  • munchkin-man
    munchkin-man Member Posts: 247
    slant fin tanks failing
    I would like to know what type of tanks are they and were are they failing. I am the tech support manager at superstor. E-Mail me back with your info and i may beable to help you. Thanks Jeff Cook
