Thremo-Shocking ?
wazy
Member Posts: 3
Who can hold better in the testing of Cast or Copper?
with return water @ 90 deg.
With a supply of 145 deg.
Cause where I work, now for 1 2/3 yrs , Slant-Fin hot water tanks keep failing
The only answer to this problem, as far as I can see is to operate both tanks at 140 deg. with constent 3 way mixing valve {supply,return,makup}
an expansion tank would help, The City of Rochester NY, said that Your system is pressuering there Mains?
any help thx?:
any help thx?:
dont understand what you mean "The City of Rochester NY, said that Your system is pressuering there Mains? "
not sure what you mean
what model slant fin? How are they failing? Is thermal expansion creeping back into the domestic water mains? A back flow preventor with double check valve and a thermal expansion tank would stop that problem.0 -
slant fin tanks failing
I would like to know what type of tanks are they and were are they failing. I am the tech support manager at superstor. E-Mail me back with your info and i may beable to help you. Thanks Jeff Cook0
- 85.7K THE MAIN WALL
- 55 Biomass
- 69 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 854 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
