What is this air vent?
Hello all, I want to replace my air valve on my steam man line in my residential home. I bought the home with a steam system and the basement was renovated so i don't have access to the mains in the ceiling. All i have access to is this dry return pipe with this old 1/8" air valve. This is what is currently there. What is a good replacement? And how do I replace this? I believe it reads No. 20 on it and it looks like a 1/8 inch thread size. Thank you.
That's been there for a while… what is the pipe it's attached to connected to? You can replace it with pretty much any standard radiator vent, but you'll need the biggest one possible. You might try a Gorton Probably not as big as you should have, but better than what you do have.D.
it’s the dry return line. I replaced it with a standard radiator air valve and removed the orifice to get the most venting.
Did the replacement show improvement @erics_guerron123? How high off the floor is that return line?
are you sure that is supposed to be a dry return?
That’s what I’m wondering @mattmia2. Thinking maybe that was a wet return once and maybe the pipe in question was a return from something above (although the ceiling doesn’t necessarily show signs of that).
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
