What is this air vent?
Hello all, I want to replace my air valve on my steam man line in my residential home. I bought the home with a steam system and the basement was renovated so i don't have access to the mains in the ceiling. All i have access to is this dry return pipe with this old 1/8" air valve. This is what is currently there. What is a good replacement? And how do I replace this? I believe it reads No. 20 on it and it looks like a 1/8 inch thread size. Thank you.
  • I replaced it with this and removed the orifice.
    Jamie Hall Posts: 28,052
    That's been there for a while… what is the pipe it's attached to connected to? You can replace it with pretty much any standard radiator vent, but you'll need the biggest one possible. You might try a Gorton Probably not as big as you should have, but better than what you do have.D.
  • it’s the dry return line. I replaced it with a standard radiator air valve and removed the orifice to get the most venting.
  • Danny Scully
    Danny Scully Posts: 1,472
    edited 10:06PM
    Did the replacement show improvement @erics_guerron123? How high off the floor is that return line?
