Need a new boiler-
sehgalr
sehgalr Posts: 1
edited 7:03PM in Strictly Steam
hi I’m located in central New Jersey (near Edison). need to replace my boiler. It’s a Burnham PInGsnc-ME2 low pressure boiler - steam. it’s got a slow leak. I wanted to replace with a Burnham but was told all the newer models had different connections and I should go with Crown/New united. Any advice on what is the best approach?
ETA: I inherited this system and it was poorly maintained. I would also appreciate recommendations for contractors if you all know of any in this area
    ethicalpaul Posts: 9,112
    edited 6:44PM
    I would not recommend Burnham. Crown is Burnham so beware there. I don't know New United?
    Look for Peerless, Weil-McClain or even Utica
    And be sure it is sized correctly. That old one is pretty massive and probably oversized.
    EdTheHeaterMan Posts: 13,054
    16 year is not that long for a steam boiler. And the installer that uses copper for the main near boiler piping is not someone that I would want for your new boiler.
    ethicalpaulmattmia2sehgalr
  • ratio
    ratio Posts: 4,358
    You really want to pick the installer & let them pick the boiler, unless you are going to do the install yourself (a real option).
    BTW, #1 is over $4.50/lb around here, you'll be able to get some beer money from all that copper you're going to tear out!
    I've never really understood this. Why would a homeowner allow a contractor (who may prefer some specific brand due to weird or self-serving reasons) to select a clearly sub-par boiler such as a Burnham or one of its many many off-brand labels?
    Someone is going to get some beer money for it!
    sehgalr
    mattmia2 Posts: 18,500
    Don't choose by price. That looks like a fairly complicated system, unless you get someone that really knows steam, you will have problems. There are several contractors here based near NYC that will work in NJ. Not sure which will work in NJ but @JohnNY @clammy @EzzyT @Mad Dog_2 are some to try.
    Is that 1 pipe or 2 pipe?
    Probably should ask if the loss of water is from the boiler too, you may not even need a boiler but some steam leaks fixed or some wet returns replaced. Did someone flood the boiler and see a leak or is there an active leak of water from the boiler?
    sehgalr
  • ratio
    ratio Posts: 4,358
    I guess the thought is to not get a crook. I suppose that isn't quite as easy as was any more.
    When I buy equipment for a job, I get what I know is the right thing for the job. If a customer wants me to install his equip, that warranty is rather more limited in scope than most people want, and if there's too much argument about sizing I'm walking away. That's one of the danger signs I watch for (customer "knows" more than I do).
    That's something we have in common! Me knowing more than my contractor is one of my danger signs too! 😅
    If only it didn't keep happening!
    sehgalr
