Shut off not working properly
deen
oiler & Control: Utica PEG187AS gas-fired steam boiler with a McDonnell & Miller Series 67 low-water cut-off, just installed a brand-new M&M 6667 (153825) replacement head.
2.
Terminals 1 and 2 are on top and wired to the burner circuit.
Pulling one wire off Terminal 1 stops the boiler from firing (so the circuit isn't bypassed).
Opening the LWCO blow-down valve produces a strong rush of water and empties the sight glass, yet the burner stays running.
need to clean out the body of the lwco, the float is hanging up on the debris inside it.
Make sure the switch is installed with 1 & 2 on top. factory might have screwed it up. Possibly a bd switch but what @mattmia2 said is more likley.
- 135 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
