Experience portable cast iron radiator heat without pipe, boiler
A put a 1500W 120V elememt into one end, filled the radiator about 80% with water.
A copper sheet bolted to the radiator with some tapped 6-32 studs epoxied in. A ty
typical electric water heater overload and t-stat. Set at 150°
Vent cap is loosened so no pressure build up.
Pic shows 15 minute and 1 1/2 hour run time.
Electrical cover in the works.
Seen them alot in Canada, and Europe.
The Science Lab lives! Looks great to me, except for the cost of electricity in my area (NJ).
nice radiator, cart makes for nice portable heat.
Just built a couple carts for two radiators I am stripping and repainting0 -
You could get gas fired ones, too…
doesn't castrads do that? is that an arco detroit pattern or whatever they call it?
could probably put a small rupture disc in the vent like they do with pressure cookers.
Just needs a low water cut off, a water feeder and a sight glass.
and a humidity control to control the steam coming out the vent.😎😎😎😎
Something to set next to the desk for intermittent use.
Yes, you can buy factory built elements. $329. for this one pictured.
This was built with misc parts in the shop.
If you have expensive power, just use a 1000W element😉
Living the hydronic dream0
- 133 Chimneys & Flues
