I think I may have overfilled my boiler...
Last Saturday I went to check the water level in my boiler, and flush the low water cut-off. I am 73 and recovering from 2 knee replacements, so I hadn't been in the basement for months because I couldn't get down the house of horror stairs safely. Only a little water trickled out when I pulled the low water cutoff lever. The heat had come on that morning, and I had hot water (hot water is off the boiler). So I assumed the boiler must be near empty since it hadn't been checked regularly for most of the spring and summer.
In February, during annual maintenance the technician noted that the glass was pretty dirty and it was leaking at the bottom and should be replaced. He also fixed my automatic water feed. However, it only worked twice and then crapped out again. I don't trust those; twice I had near disasters when it malfunctioned and started to overfill. For the last few years, I have been checking the water level weekly and filling manually as needed.
I am noticing a bit of a rumbling sound sound when the boiler is running. My radiators are hissing more than normal. But several radiators are not getting hot. This morning the glass looks different, like it may be full of rusty water. I let a bucketful of water out, but still could not see the water level. After the bucket cools, I'll empty it and take some more out. I read that there is a pencil trick to see if the sight glass if actually full. I don't have a good way to get a lot of water out of the boiler. I'm not sure what the technicians do. They might be somehow dumping into a main drain somewhere. Since it's too hard for me to carry the bucket upstairs, I just usually dump it in the dirt crawl space, or, it just evaporates between times when I flush the cutoff valve. Any suggestions until I can get the guys here and get the glass replaced? Although the boiler is 21 years old, the technician commented that it was a very clean system and in good shape. Thanks for your help. You folks have helped me a few times over the years.
    pecmsg Posts: 7,619
    Unfortunately, you do need someone on site. Are there qualified tech out there yes but few and far between. When you find on hold on to them.
    Where are you located, we may know someone.
  • I live in South Portland, Maine. I have been using Heritage Home Services. My daughter said last time she looked she could detect the water level. She's coming by later.
    Have I created an unsafe situation? Should I turn the heat off?
    Jamie Hall Posts: 27,916
    Not unsafe but possibly unfortunate. An overfilled boiler can put water up into the mains, which can get water into vents and places it really shouldn't be. And the system will heat poorly.
    The pencil trick does work — hold a pencil crossways behind the site glass and look slightly down at it. If there's water in the tube, the pencil will look broken and not straight across. If there isn't, it will be more or less straight.
    LynnLennox
    pecmsg Posts: 7,619
    Heritage Home Services sounds like a home warranty company; I'm not a big fan of those types of repair companies.
  • They do plumbing, HVAC, electric. They seem to know what they are doing.
    pecmsg Posts: 7,619
    Here finding "Qualified" techs is almost imposable and very expansive. Warranty companies pay poorly, few if any benefits.
    Annual Maintenance in February is rather late in the season.
    Did you have to pay for the Water Feed? Was it really broken or just a way of padding the bill?
  • My daughter drained several buckets of water and we were finally able to see the level start dropping by shining a flashlight. The water was so murky that the pencil trick didn't work; we couldn't see through the rusty water.
    We drained it so it was a quarter inch below the max fill line so I could get an idea of how many seconds it would take to move it back up to the line.
    I'll make sure they swap out the glass and fix the leaks when I have my annual maintenance.
    Any opinions on automatic water feeds? I was lucky to be home both times mine malfunctioned and would not stop filling. So after a replacement and a couple of repairs, it is now NOT working and I'm going to leave it that way. I flush my cutoff valve weekly during heating season, so I might as well just add water, if needed, when I'm doing that.
    Sounds like you have it under control now! Shout out to your daughter.
    LynnLennoxGrallert
  • Grallert
    Grallert Posts: 1,220
    Two things, Daughter are great! Just make sure your low water cutoff is working and you need to figure out where your water is going. That's three things…
