Heat pump, supplemental gas boiler versus oil fire boiler
debating putting a new system with heat pump with the the gas propane fired boiler to make up the difference on those cold days versus the straight up oil boiler that I have now that heats a Hydraulic baseboard any comments I am not contractor a lot of different wondering what y’all think Thanks Pete
    Jamie Hall Posts: 27,894
    Two different questions. The first question is the heat pump. Newer heat pumps do remarkably well even in colder climates, and whatever you do on the second question I would at least investigate installing one — probably mini-split, but there are other options. Then the second question is… why are you considering switching to a gas or propane boiler from the existing boiler? Even at current fuel prices it will take quite some time to recover the capital investment of a new boiler, so I wouldn't recommend switching unless the old boiler is giving trouble. You certainly won't save by putting in a smaller boiler — that would be a real mistake, as you need what you have on the coldest days, when the heat pump will lose capacity.
