mod con intake filter build
Using a common K&N universal filter. No name knock-off of this filter for around 35 bucks. This model slips over a piece of 6" PVC thin walled PVC. I imagine you could find a 2" version.
The aluminum adapter plate just slips over the 2" intake PVC.
I want to keep woodworking dust out of the machine.
I doubt a manufacturer would approve this without some extended testing?
I believe you are doing the testing yourself at this point. How often would you need to service/clean/replace the filter would be determined by the amount of dust collected by the filter.
previous I pulled outside air into this boiler. It did have a number of bugs in the burner when I serviced it last year.
just moved it across the shop, thought I would try inside air this time.
But why stop at such a small filter. Why not build something that is 28" x 28" x 24" that can hold 5 filters like this:
what drove the move? Always curious about people change thier shops; I envisions your as a hydronics experimentation lab.
K&N filters are made for an oil spray on the filter media. That's where it gets its excellent filtering without a loss of air ingestion. Its washable and re-useable. Lifetime.
As I recall the K&N has a greater filtering capacity, micron size particles, than a paper filter without compromising flow. In the long run it is cheaper than paper.
if a 90 adds like 5' i don't want to know what that adds
You should be able to calculate the equivalent feet the filter adds with a manometer?
this boiler is allowed 40’ of 2” pvc intake.
I don’t think this filter would be a restrictive as the much piping? Obviously as it plugs up the resistance increases.
I think chocking the intake reduces the firing rate.
The Aerco Benchmark used a 16x20 furnace filter, those boilers start at 750,000 btu input
