mod con intake filter build
hot_rod
hot_rod Posts: 28,699
Using a common K&N universal filter. No name knock-off of this filter for around 35 bucks. This model slips over a piece of 6" PVC thin walled PVC. I imagine you could find a 2" version.
The aluminum adapter plate just slips over the 2" intake PVC.
I want to keep woodworking dust out of the machine.
I doubt a manufacturer would approve this without some extended testing?
Screenshot 2026-10-10 at 4.03.26 PM.png Screenshot 2026-10-10 at 4.03.09 PM.png Screenshot 2026-10-10 at 4.03.03 PM.png Screenshot 2026-10-10 at 4.02.52 PM.png
    EdTheHeaterMan Posts: 12,940
    I believe you are doing the testing yourself at this point. How often would you need to service/clean/replace the filter would be determined by the amount of dust collected by the filter.
    previous I pulled outside air into this boiler. It did have a number of bugs in the burner when I serviced it last year.
    just moved it across the shop, thought I would try inside air this time.
    But why stop at such a small filter. Why not build something that is 28" x 28" x 24" that can hold 5 filters like this:
    HeatingHelp.com
    I could rent space to my neighbors on that filter rack
    EdTheHeaterManPC7060
  • PC7060
    PC7060 Posts: 1,980
    edited October 11
    what drove the move? Always curious about people change thier shops; I envisions your as a hydronics experimentation lab.
  • pedmec
    pedmec Posts: 1,488
    Aerco Boilers use the KN's for their Benchmark boilers. Should work for yours
    hot_rod
  • HomerJSmith
    HomerJSmith Posts: 2,837
    K&N filters are made for an oil spray on the filter media. That's where it gets its excellent filtering without a loss of air ingestion. Its washable and re-useable. Lifetime.
    As I recall the K&N has a greater filtering capacity, micron size particles, than a paper filter without compromising flow. In the long run it is cheaper than paper.
    I replaced my boiler with an A2WHP, so the boiler moved to another location, but is piped for backup if needed.
    Yes I do have some wall space for testing hydronic ideas and components.
    PC7060
    if a 90 adds like 5' i don't want to know what that adds
  • You should be able to calculate the equivalent feet the filter adds with a manometer?
    this boiler is allowed 40’ of 2” pvc intake.
    I don’t think this filter would be a restrictive as the much piping? Obviously as it plugs up the resistance increases.
    I think chocking the intake reduces the firing rate.
    The Aerco Benchmark used a 16x20 furnace filter, those boilers start at 750,000 btu input
