Heating issue: heat is not reaching the second floor thru the wall units
Raiburnj
Raiburnj Posts: 1
edited 10:09PM in THE MAIN WALL
I have a Eeil-McLain boiler it has a tag on it. CP1310144. It was installed June 5, 1987. The manual says it covers series one and series 2 information.
The valve that goes to the 2nd floor was replaced last week because the hot water was not flowing through the valve for the second floor. now the hot water is flowing through, but there’s still no heat coming to the second floor. What would be the next step to possibly fix?
  • Ironman
    Ironman Posts: 7,957
    edited 1:58PM
    Uh, you’re gonna have to be more detailed in your description. What valves were replaced? Zone valves? Boiler isolation valves? Radiator valves?
    “hot water was not flowing through the valve for the second floor now the hot water is flowing through, but there’s still no heat coming to the second floor”. This sounds confusing. Please explain more clearly.
    What type of heat emitters do you have?
    Bob Boan
    pecmsg Posts: 7,571
    Agreed What Valves?
    Was the 2nd floor emitters bleed?
    Who did this work?
    hot_rod Posts: 28,408
    Any work that required draining the system would require a good purge on all the zones.
    Zone valve motors could be replaced without a drain down.
    Pictures would add some detail to your question
    EBEBRATT-Ed Posts: 21,080
    Call the person that did the work back and tell them it isn't working.
    The pipes are probably air bound and need bleeding.
    And don't pay them anything additional it should be part of the install.
    HVACNUT
    HVACNUT Posts: 7,704
    If you paid someone to do repairs, it should work before payment. If its not working, call them back. It might just be air locked.
    If you did the work yourself, post some pictures.
