PressureTrol with dirty pigtail
simon_skove
I removed the pressuretrol and pig tail (with the boiler off) and found the pig tail was clogged.
Should I be concerned about the pressuretrol being damaged or clogged?
Thanks,
Simon
Nope. Never seen a pressuretrol damaged because the pigtail was plugged. The replacement pigtail should be brass, so it won't rust shut.
2 -
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
