Techniques for Replacing 3" Boiler 3-Way Elbow
I would like to replace this 3 inch elbow with a simple cap.
The boiler was new in 2007.
Although I have a 36 inch pipe wrench, a Sawsall, and Kroil, I absolutely do not want to crack the boiler in the process.
What would be the recommend procedure?
It looks like it is being used, why replace it with a simple cap ?
One Pipe System0 -
Why replace it?
- I am relocating the feed to the other side.
- There is already a drain valve.
- The multiple bushings have always offended me.
What is a Heel Tee?
I suppose technically it is a 3 x 3/4 x 3 tee
In the plumbing world it might be called a heel outlet ell
Thai is a ;lot work to go through just because you don't like the looks of it and there is some risk of damaging the boiler. i would leavr it be amd make sure the 3/4' plug is brass so it's easy to remove.
Bob
3PSI gauge1 -
Heat, lot of heat. But don't burn the jacket
That's a lot of work and a lot of risk to go through to satisfy aesthetics. @BobC has it right, but if you want to spend the time and the money to make it look purty, that's your puppy.
You can crack a cast-iron fitting , and spin it off to clean the treads . It is the rason why we will use a cast fitting .. Easy for repairs down the road. Use a hand held lug hammer to hold on oppersite side of fitting and hit the other side with another hammer .. The ring sound will disappear when fitting is cracked .Once you hear the change of tone .. Then spin the fitting off to clean the threads … Don't beat the remainder off which could damage the nipple …. Good luck
Get a plug and a drain with the appropriate bushing and call it a day. Seriously.
This is one of the times the lazy way is actually the better way.
I understand you'd rather it be perfect, but a cracked boiler is going to offend you a whole lot more.
2 -
If you are relocating the feed to the other side, just remove the bushings and put the appropriate sized plugs on it. Not worth the risk in my opinion.
If you insist on removing it, cut through it to the threads of the fitting without cutting into the nipples threads. Use a chisel to break the remaining threads to separate it. Should break the bond enough to remove it. Even then I wouldn't want to do this. I'd be afraid the impacts might crack the boiler.
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
