How to remove old fittings
That fitting looks like it has been installed using "grip" as a sealant, which very effectively dang near welds the fitting on.
What I would do is put the pipe wrench on the pipe with the pipe on the left side and the handle straight out, and you standing so your left side is next to the wall, and then put at least an 18" crescent style wrench on the fitting with its handle a few inches in front of the pipe wrench. Then put the pipe wrench against your chest and lean on it to hold it in place. then grab the crescent wrench and pull toward you until either the fitting comes loose, or you chest hurts too much. Expect some chest bruising if it is too tight. You can also put some padding on your chest before you start. If that doesn't work, a lot of times you can go the other way until it moves, and then try removing it with the wrenches set up like before.
Rick
was the title and looking at all the responses from @azward I have a feeling that he is related to a guy that worked for me that didn't have the mechanical aptitude but was really book smart. Understood what was needed but could not apply the concept manually.
This is a how he might remove old fittings from my garage.
And he would be correct in his mind, but wouldn't have accomplished the task I needed him to do
@EdTheHeaterMan just saw your post. I haven't got a chance to touch that fitting yet, being busy deflecting balls of life. maybe it's better push it back until the gas inspection is done. I never thought these cast iron fittings are so tight, so it is challenging. The good thing is you guys are here to light the way.
you could put a flare cap on it to pass the inspection.
To eliminate the entire system would require finding a location for the thermostat wires on the intelligent boiler control, because the boiler thermostat connection is located on the IQ panel. That is why it took me about 2 hours to remove the IQ panel. I needed to determine where all the unused wires needed to go, including the thermostat wires.It is doable — I just cannot remember the exact details because it was so long ago. I believe the yellow wires connected to the 9-pin P5 connector, terminals 9 and 7, might have been the thermostat wires, but it has been long enough that I cannot be certain.That will probably require some trial-and-error testing to determine whether the yellow wires are 24 VAC power from the transformer or the actual thermostat wires. A meter may help you determine that. Try connecting the yellow wires together with a fuse. If the fuse blows, then it is 24 VAC power for the IQ panel. If the system starts, then it is the thermostat circuit.After that is determined, you can proceed with removing the IQ panel because all the remaining wires will be EnviraCOM system wiring that you are not using.
This is the second time this has happened to me this week. Apparently, I need more spinach salad and salmon for memory enhancement—or at least a bigger supply of sticky notes! 😄Edward Young Retired
@EdTheHeaterMan this is the gas pipe for a dryer, not a boiler. you are probably posting to another thread?
Cross reference to dope & tape in this conference. Tapered thread connections can be problematic. There are alternatives.
It does look a slightly crooked.
One Pipe System0 -
I cannot tell from the photo, is the hoe wrench 18 or 14 inches?
Hi @azward , The Hoe wrench is 14". They were made in a pretty wide range of sizes. Here's one for sale on Ebay now. 😉https://www.ebay.com/itm/136848994832?_skw=hoe+wrench&itmmeta=01M02YP33T941JGYAA6VDQC0AQ&hash=item1fdcd5f210:g:YkoAAeSwvZ9pPx-V&itmprp=enc%3AAQALAAAA8GfYFPkwiKCW4ZNSs2u11xAwlnp3Pxse9piMBDtUy1JuoWHHl57nt6DeFGTruZbCIAt4iJYBhwmf0wzFDE80PK5H7f5vltbX4OrBY64DeQuDdDv%2B4FZBxJc8DsYsPwBO%2FUiex3ZE4tM33NpjcmeiCNNf8M%2B%2BYnE4P7jtwQIjpPE17NlSBcEQLI5e0%2BsfJNGbH3qpuWN3Pg1IMCtmgjwEgeQs7dsY%2BhJP%2Bwsza1Q589pVfa%2BQRtYj7kwRTqh%2FDnmBCofgoz21vYI8M65Ms%2FzuS052rtJy4u%2BxQviYaLR8WoSWnlslHdiznrN%2FDvqLZ%2Fx5aw%3D%3D%7Ctkp%3ABk9SR5yy2N6AaA
18" is also available for the hoe wrench. Both lengths are also available for the monkey wrench. Need to pick a length.
I know there is a cheater bar available, but still debating which length is more useful..
These vintage tools are for collectors and restoration hobbyists, right?
The teeth on the jaws may have been rounded off over time. Then it's another project to restore the jaws.
Out for my 3 mile walk today and walked by a tag sale. I didn't see anything much at first but then saw a hand saw handle sticking out of a box. I walked over and the young lady said, "The tools are in that box". I said, "how do you know I am looking at tools?"
She said "you look like a tool guy"
So I couldn't resist a 14" Walworth Stillson pipe wrench in really good condition (a little rusty with a small chip in the lower jaw) for $1.00.
Then an Irwin spring clamp for a $1.00 and a Hyde razor knife because I only have a 1/2 dozen of those already for $1.00.
I am supposed to be getting rid of tools
What the hell is wrong with me anyhow??
2 -
I tried to buy only the bare minimum tools, but recently have placed orders more frequently and been attracted by more expensive tools
Hi @EBEBRATT-Ed, Happily, I have the same sickness 🥳 … @azward, I use a grinder on a Dremel tool to sharpen the teeth on pipe wrenches. It takes just a few minutes, and does a lot to prevent slipping.
Yours, Larry
3 -
me too
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
