Remembering Binyomin
On January 19, 2024, 11-month-old Binyomin Kuravsky took his first steps. The next morning he was gone , killed by a sudden steam radiator failure in his Brooklyn bedroom. Remembering Binyomin
Boiler Lessons
A freak accident. How terribly sad. My heart goes out to the family.
Thank you for highlighting the dangers of steam burns Ray.
I think it's fair to ask what steam pressure they were running.
Consulting0 -
I would bet my boots, that that the radiator was somewhat elevated from the ground. And that they were supports under the legs on the air vent side and no supports under the legs on the shut-off valve side. Which means that the valve spud was supporting the weight of the radiator. Give it enough time and the spud will crack. I've seen this happen numerous times.
Tragic regardless
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
