Fitting ID Question
Hi all,
Below are 2 photos of a pipe leading into a T above my boiler. Is this some sort of union where the pipe on the left meets up with the T?? (Ignore the white circle - it's just a light bulb in the basement.)
    hot_rod Posts: 28,528
    it looks like a reducing bushing. I don’t think it is a union?
    mattmia2PC7060
    pecmsg Posts: 7,613
    agreed reducing bushing
  • MrCofDG
    MrCofDG Posts: 42
    Ah. Thanks gents.
    EdTheHeaterMan Posts: 12,857
    edited July 14
    BLACK BUSHING: ADVANCED ENGINEERING FEATURES
    The black malleable iron bushing represents a remarkably refined solution to one of the piping industry’s most important challenges: reducing a larger threaded opening to accept a smaller pipe or fitting.
    While it may appear to be a simple piece of threaded iron, it is actually the product of generations of metallurgical development, dimensional standardization, precision machining, and practical field experience.
    Malleable Iron Construction
    Manufactured from ASTM A197/A197M-compliant malleable iron, the bushing provides an ideal balance of strength, durability, and workability. It is strong enough to withstand tightening forces, vibration, thermal expansion, and long-term service, while remaining practical to install using ordinary pipe-fitting tools.
    In other words, it is tough enough to do its job without requiring the equipment normally associated with bridge construction.
    Standardized Thread Compatibility
    The bushing meets B16.39 requirements for malleable iron fittings and uses pipe threads manufactured in accordance with ASME B1.20.1.
    These carefully standardized tapered threads become progressively tighter as the fitting is installed, helping provide a secure mechanical connection and dependable seal when used with an appropriate thread compound or sealing tape.
    Compact Size Reduction
    By combining a larger external thread with a smaller internal thread, the bushing allows two different pipe sizes to be joined without requiring additional nipples, couplings, or adapters.
    This compact design saves space, reduces the number of threaded joints, simplifies installation, and helps prevent a basic piping modification from becoming a full-scale mechanical reconstruction project.
    Dependable Performance
    When properly selected and installed, the black bushing provides durable, long-term service without motors, electronics, batteries, software updates, Wi-Fi, or monthly subscription fees.
    It simply reduces one threaded pipe size to another with efficiency, reliability, and a level of mechanical dignity rarely achieved by any object small enough to fit in the palm of your hand.
    The black malleable iron bushing is more than a fitting. It is a compact monument to standardized engineering and one of the quietest yet most important achievements in the history of threaded pipe.
    Steamhead Posts: 18,974
    Does it also feature "obfuscation"?
    Semi-retired
    You know what my doctor said to me at my last checkup? "Ed you are quite sedentary"
    Once I heard that, vowed then and their that I was going to do something about that!
    Go out and buy a dictionary!
    mattmia2 Posts: 18,233
    is this what the description of the cigarette lighter in a bentley sounds like?
  • Intplm.
    Intplm. Posts: 3,156
    @MrCofDG That is a bushing, possibly a 3/4" x 1/2" or 1" x 3/4" bushing. It is not a union.
    Union.
    Bushing.
    EBEBRATT-Ed Posts: 21,169
    @EdTheHeaterMan description does not allow for CI bushings.
    In the supply houses I usually went to bushings were usually steel (in smaller sizes) and CI in larger sizes.
    Obviously inferior to the malleable bushings above LOL
    Not sure I ever saw malleable bushings.
