Gas water boilers Weil Mclian or Peerless (WeilMclain no longer uses metal Push nipples).
jgg765
jgg765 Posts: 6
edited June 27 in Gas Heating
TITLE:
Hello,
I am looking to replace my gas hot water boiler (not steam). It lasted about 37 years, but it is leaking underneath I am assuming it is the block either way it is almost 40 years so time to replace.
I do realize and it has been said many times on this forum the most important aspect is the installation which I am getting a licensed plumber to do.
There has been some post on this topic below but I have some other questions as well.
LOOKING FOR YOUR VOTE:
The information I am looking to gather from you is would you purchase the Peerless or the Weil McLain see details below.
MAJOR QUESTION WEILMCLAIN IN THE PAST VS TODAY PUSH NIPPLES:
I know WeilMclain have a good reputation my neighbor has 1 that is 40 years old. However in the past they used to use metal push nipples. However, now
They are Building the units with Synthetic elastomer (often EPDM or similar high-temp rubber).
Peerless on the other hand use Metal Cast Iron Push Nipples.
PEERLESS BENFITS AND CONCERNS:
I had 35 years of good service with the boiler.
I was going to replace it with the Peerless MI-X-03 (I am leaning more toward this.
The Weil Mclain replacement equivalent Weil-McLain CGa-3 (or CGa-3-PIDN) the thing I do not like about the Weil Mclain besides the nonmetal push nipples is it has an electronic board on it. The Peerless seems to be simpler.
PROBLEMS:
A plumber said peerless was sold and they had different owners and some units have problems recalls does anyone know of this.
ACCESSIBLITY OF PARTS.
The downside with the Peerless is I had a call about 10 places to find
someone that had 1. That concerns me what I thought I must get parts.
THANK YOU:
Thank you every body for reading my post!! Happy Fourth of July everyone.
    Jamie Hall Posts: 27,832
    Eh? At least some Weil-McClains have used elastomeric gaskets between sections for years (EG the -80 series in steam). without them being the cause of problems — provided, as always, that they are assembled correctly.
  • jgg765
    jgg765 Posts: 6
    @Jamie Hall Thank you!! I just wonder 10 or 20 years from now if they will last I would think metal push nipples are better but I could be wrong.
    Steamhead Posts: 18,915
    FWIW, I see quite a few older W-M CG series boilers and they seem to hold up well.
    Semi-retired
    Mad Dog_2
    Cedric is one such critter — and is 16 years young and going strong. I might point out that the gaskets in question are very well protected, so most environmental hazards for gaskets can't even get at them, never mind hurt them.
    Metal push mipples can and do rust out. There's no magic bullet.
    EBEBRATT-Ed Posts: 21,056
    Pick the boiler that matches the heating load the best. Peerless or Weil McLain are both fine.
    HVACNUTSTEAM DOCTORMad Dog_2
  • STEAM DOCTOR
    STEAM DOCTOR Posts: 2,661
    In my findings, the WM boiler will almost always outlast the gaskets.
  • jgg765
    jgg765 Posts: 6
    @STEAM DOCTOR thank you very much good point I did not think of that and everyone thank you for your help.
