Steam From Scratch
Just bought an 1840s farm house in Connecticut and am trying to restoring it.
I've put in steam before but never from scratch. I already have my EDR roughly figured out but am still figuring out all the supply piping. I'm thinking of doing 2 pipe with water traps on the 1st floor and 1 pipe to the 2nd floor. Or Just 1 pipe all together and forgetting the 2 pipe.
Any one have any tips or advice if you were to do this? Ive cracked open my old copy of the Color of Steam and a few others, but would appreciate to hear what some old timers might have to say about this.
Mad Dog_2
    I would do hot water with cast iron radiators because it has a lot more control options and the routing is much less critical so you have more options to get it in to an old structure, but if I were to do steam I would do 2 pipe and set it up as a vapor system with orifice plates because that also gives you more options for control.
    Another option would be to do steam for the 1st floor and do a hot water loop off of the steam boiler for the 2nd floor.
    Lovewell
  • Lovewell
    Lovewell Posts: 6
    Vapor system isn't a bad idea. I was planning on using danfoss thermostatic valves that go between the vent and the radiator which I've had lots of luck with in the past. So I can individually control each one.
    I also like the idea of only steam cause if it goes down it wont freeze and crack the radiators on the upper levels if done right.
    I'd agree with vapour type two pipe system. Orifices are nice, but if you get them too big you can just close the feed valve until you are happy. Or open it if your mother-in-law is feeling chilly…
    And I'd use traps on the radiator outlets. Much less critical.
    As far as routing pipes. If you can get at the basement — which I assume you can — I'd be totally honest about it and run the risers to the radiators on — not in — the walls where they need to be conveniently, and short runouts either under the ceiling or near the floor if they are needed. Separately to each radiator.
    Don't get fancy with the pipes — a good honest visible addition to an old house, particularly if you are leaning towards restoration rather than some fancy renovation, is much the best approach.
    If you don't have a copy of The Lost Art of Steam Heating (the store on this site, or Amazon) get it…
    garretjhfixitguyjamplumb
  • Mad Dog_2
    Mad Dog_2 Posts: 8,755
    This is awesome 👌. Is there something that intrigues you about The Steam? Are you trying to restore the Farmhouse to that era? I don't regret installing my Vapor System from scratch going on 25 years now. You do have great radiation options like Castrads to recreate that feel. As Mattmia said, a Hot water hydronic system is an option too using the same ornate radiators. Mad Dog
    Lovewelljamplumb
  • Lovewell
    Lovewell Posts: 6
    I've been rescuing and restoring a bunch of original American Radiator steam radiators. I'd rather give them some new life and save them from being turned into paperclips. I love steam, plus its the only type of heat my wife has no complaints about. Also I like the idea of something that will outlive me and is actually well built. Its more than can be said about mini splits that are being used to butcher beautiful older homes.
    dabrakemanRobert_Hjamplumb
  • Mad Dog_2
    Enough said! Do you have The Lost Art of Steam Heating? Mad Dog
  • Lovewell
    Lovewell Posts: 6
    Indeed I do! I was also digging around in radiant heating and cooling by napier adlam since I know Dan Holohan referenced the book more than a few times
    Mad Dog_2
    i doubt it would be economically practical but i wonder if yo could do radiant cooling with ci radiators. you would have to do the supply dehumidified air thing to keep the dewpoint below the temp of the water.
  • Lovewell
    Lovewell Posts: 6
    I'm more so reading that book for the heating and snow melt aspects. The cooling Im sticking with plain ductwork
  • Lovewell
    Lovewell Posts: 6
    But you certainly could. Ive done radiant cooling with a slab before you just have to dehumidify the air a LOT with auxilary dehumidifiers like the ones that aprilaire makes
    edited June 2
    I’ve always liked the photo of the journeyman in the jacket, tie and fedora helping to carry a radiant assembly. Imagine.
    mattmia2Larry WeingartenGGrossjamplumb
    My brother talked to an old timer plumber that worked in NYC. In the old days they would travel on the Subway, and the plumber carried the toilet tank and the apprentice carried the toilet bowl……………………………..or maybe it was vice versa.
    jamplumb
  • Mad Dog_2
    We've done that. Not with a toilet , but with oat sacks of fittings and tools. We used shopping carts in and around Rockefeller Center. Mad Dog
  • BobC
    BobC Posts: 5,578
    Where there's a will there's a way.
    3PSI gauge
    Mad Dog_2
  • For a system like that you may want to look at the steam minitube system or some variation thereof. In my own home I ran a single 2 inch main next to the center beam and then took larger steel branches off that (1/2 and 3/4 inch) to the exterior wall and then ran 3/8 inch copper flex up to feed the radiators which have orifice plates. All the returns were done in small copper tubing. Unfortunately I haven't run the system as steam yet, I'm running hot water right now but hope to switch back and forth to run performance and efficiency tests. I have very low loads, only about 40,000 btu/hr design for about 2,050 sq ft, so the radiators are pretty small.
    Another steam minitube variation I have installed is one pipe steam. We ran the typical 1 inch copper steam mains to the front and rear of the home. The 3/8 inch supplies came off the bottom of the mains and ran into an union with an orifice and then into the side of a tee. The tee feed up into standard one pipe steam risers to the radiators and the bottom of the tee ran down to a 3/4 inch wet return. This was an existing system with typical oversized radiators, so the orifices allowed us to downsize the boiler to the current heat load. We had to sort out a few things at first, but now the system runs very nicely.
    Mad Dog_2mattmia2jamplumb
