Expansion Tanks
I want to reduce my truck and shop inventory. Currently stock small and medium tanks for both potable and hydronic systems. They're large and take up a lot of room. I don't mind paying a bit more for a potable tank, but I'd like to find these tanks made with ½" connections and I seem to remember these being available, but can't seem to find them now. That would allow me to carry just one set of tanks. And I'm sure the potable tanks last longer than the non-potable ones.
Does anyone know a source for these?
Watts , Taco and Amtrol are all 3/4" as far as I can find.
Could you use a reducing coupling and 1/2” nipple for the heating application?
The Amtrol Radiant Pro is basically their Thermtrol with a 1/2" connection. However it doesn't have the NSF listing as a potable water tank. But same poly lined tank used in the ThermTrol.
ThermTrols are rated 180F, whereas the hydronic tanks are 200°. So use a ThermTrol only on low temperature hydronics.
Evan will be doing Coffee with Caleffi on June 25. Their family has been long time Amtrol reps and he does trainings at the Amtrol facility and helped build their training lab. So bring your expansion tank questions next week.
There is a movement towards flow thru DHW expansion tanks to prevent legionella growth.
Although Amtrol uses a turbulator on their DHW tanks to mix up that water in the tank, and antimicrobacterial liner.
The only 1/2" DHW tanks are those 1/2 gallon made for tankless water heaters, like the Zilmet stainless one. Larger commercial size DHW tanks actually go to 1" connection
Why not just keep a 3/4 X 1/2 stainless of brass bell reducer and nipple to use the DHW tank on hydronics?
wouldn't the schrader have to be leaking for that indicator cap to work?
Who woulda thunk it? I just looked at the patent, and the screw-on cap depresses the pintle on the Schrader valve when you screw it on. The cap has an o-ring to provide its own seal against the body of the tank. Then the volume of the cap is "in communication" with the air in the bladder. If the air in the bladder gets moist from a leak, it changes the color in the cap.
Trying to keep Bernie burning!
3 -
so instead of relying on both the o-ring and the schrader, to have at least one of them hold, we need the o-ring to hold.
tried doing commercial refrigeration!
eight cylinders and three recovery tanks
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
