Help Identifying Fitting
Can someone identify what this fitting was used for and how old it may be?
looks like a gas cock, probably for a portable space heater or gas lamp. is there other evidence of gas lighting? probably from the late 19th century to the 1920's.
old gas cock
high school Science class
Very old homes and buildings in old cities used natural for lighting the rooms. Be careful, sometimes they are still live and connected. Mad Dog
Thanks for the answers everybody. I’ll be sure to check if they’re still connected to a live gas line.
i mean they usually used town gas/manufactured gas which was carbon monoxide. natural gas would have been far safer. they usually got connected to the natural gas system when it came to town in the 40's and 50's.
the op asked what connected to the barb in a private message. some people will know more than me here so i'll post the answer publicly:
just a hose that would shove over the fitting, probably just rubber tubing but that is a little beyond my historical knowledge. gas is under very low pressure, gas piping is more like ductwork than piping, the tension of the rubber is enough to keep it from leaking. it is like a chemistry laboratory. there are engineered connectors for labs with reinforced hoses and rubber bushings that connect to the barb now but in the early 90's when i was in high school those were just becoming a thing so i don't know if there was a heavier duty connector for them in the early 20th century or if it was always rubber tubing.
@mattmia2 You are correct. it was just a rubber hose that connected a portable lamp that might be moved from a table to another room, kind of like plugging in an electric table lamp to that thing Thomas Edison was pushing at the time.
if you want to be technical about it hubbell invented what would become the 1-15p and 1-15r plug and receptacle.
We had those barbed end fittings on a gas line in the high school science lab to add a "Bunsen Burner" that could be used for anything requiring a gas flame.
This reminds me of a night call I received at the high school in Sewickley, Pa. for "no heat". On a Friday afternoon just as school let out for the weekend a student ran a section of flexible tubing from one of these gas fittings to a sink outlet that also had a similar barbed fitting on the spout. He or She turned on the gas cock and the sink faucet and fed the water into the gas line. The water ran until Sunday when the gas company began getting no heat calls from people living near the school. The water filled the school's gas lines and continued into the gas lines of the nearby homes. ( This sounds like something any mischievous boy would do.)
Our 1850 farmhouse in MI had lighting fixtures with gas-cocks like that, that ran on acetylene gas made from a gas generator that used calcium carbide and water.
Might have also been for a gas heater.
they still do although they have vacuum breakers on the faucets now. i guess that wouldn't have helped.
one of my classmates did that with a fetal pig.
Considering the gas valve was installed so low to the floor it was probably installed for something like this.
2 -
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
