Slow shower head drip from a KOHLER 8304-K-NA Valve Body
Woke up this morning to a slow drip on a 2 year old valve body. Had a spare cartridge and swapped in after cleaning the valve body and lubing built in o-rings with petroleum jelly.
Still have the slow drip. Inspected the valve body interior, all looked clean, no pitting.
Any suggestions?
look at where the o-rings seal. I think that kohler cartridges have been ceramic for decades so the part that is going to leak is the seals to the ceramic parts.
I initially thought it was a leaking o-ring but notice the valve will leak with unless both supplies are shut off
Must be leaking through the cartridge somehow but is odd that two cartridges are doing same thing.
I may just order a new cartridge since both of the current unit are previously used.
Interesting finding, the leaks stops when i loosen (unthread) the chrome control handle 1/4 -/12 turn. This threads onto a plastics assemble which is in turn threaded onto the cartridge. Wonder if the force is pulling the cartridge body enough to cause the leak
new cartridge coming in tomorrow. I believe you have it right; the o ring don’t recover from extended install.
they usually are made of the compounds that are just sort of resistant to water and chlorine and chlorides so after sitting in water for 5-10 years they become brittle instead of pliable. sometimes cleaning the seats in the valve body with vinegar or citric acid can also help but do not use abrasives, sometimes those can leave scratches that prevent it from ever sealing properly again.
Dont use petroleum based lubes… Vaseline incl. Silicone grease is the best option. The petroleum will degrade the O-ring.
it isn't flimsy, the compound is just chosen by price instead of chemical resistance. the compound the chose would be fine in some applications.
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
