Want a Wall Mounted Ductless Heat Pump
2»
    pecmsg Member Posts: 7,171
    I advise against that.
    Finding a Diamond dealer that will install it will be almost impossible.
    Finding a qualified contractor that will install it will also be almost impossible.
    Warranty WILL be a problem!
  • kadini
    kadini Member Posts: 70
    Well what should I do?
  • winnie
    winnie Member Posts: 73
    Either get a cheap unit and find a contractor who will just do the job (zero warranty) or pick a good contractor and have them supply the unit (full warranty).
    The first approach is cheap but you are running unprotected. The second approach will probably be 2x or more the price.
    Do not expect to buy a unit and have a contractor install it and expect a warranty. If the contractor is appropriately licensed, you might be able to pull off the warranty, but you will be on the hook to interface with the vendor, and you might be in the position of the vendor supplying the parts while you have to pay for the labor. When a contractor provides you with soup to nuts service, they mark things up to cover the cost of providing the warranty, but then they are holding the entire bag for the warranty service.
    For what its worth, studied online, got my EPA 508 certificate, bought 5 'new-old-stock' Fujitsu units, and installed them in 2023. Zero warranty, zero problems. Used for air conditioning and shoulder season heating.
    choose a great contractor.
    let them decide what brand there comfortable with.
  • ChrisJ
    ChrisJ Member Posts: 17,477
    edited April 26
    I think that's what they meant but it's worded a little confusing.
    I don't think they meant buy equipment themselves and then have someone install.
  • kadini
    My intent was always to buy the unit from the contractor who will install it. The 1st (only) person who has responded from Mitsubishi's list also does Fujitsu and Daikin. They said they'd give me an estimate for all 3.
    GGross
  • J. WALTER BOOTH
    J. WALTER BOOTH Member Posts: 26
    you still have the option of finding a LG art gallery picture frame unit
    there are a few still out there and you can still display your artwork
    i know we still have a few instock
    w
  • kadini
    edited April 28
    One of my contractors who will be giving a Mitsubishi bid also recommended Samsung. This would be purchased thru Costco and installed by their (the same one who is recommending Samsung) contractor. So what about Samsung?
  • ChrisJ
    I don't like the sound of that.
    Run fast!
  • kadini
    1st contractor came out. Gave me 3 estimates a Mitsubishi premium a Standard Mitsu and a Daikin. The Daikin was recommended. The total turn key bid was just under what I was hoping for. That said knowing approximate equipment cost it's kind of depressing knowing how much they'll make for 3-4 hours work. But 60 month interest free financing! I was planning to pay cash but how can I pass that up?
  • ChrisJ
    Would it make you feel better if they got it done in 10 hours instead of 4 for the same cost?
  • ChrisJ
  • kadini
    edited 12:52AM
    I knew you were all having trouble sleeping waiting for this. Sorry for the delay.
    Had an 18,000 btu Mitsubishi mini split installed today.
    I have a grace period for comebacks so plan to get them to relocate the head unit (center) and square it to the painting below.
    No point in lining everything up until the head unit is properly centered and leveled in the space but you get the idea what it will look like.
    Heat pump on the external wall precisely located to allow full opening of garbage cans.. Really impressed with the installation, and the installers.
    I set the cooling temperature to 66 deg. F and turned on the recirculating fan on the furnace and the temperature on the hall thermostat has dropped from 71 deg. to 67 in maybe 20 minutes. So seems to be working as hoped. It's a beautiful day here in the 60s not really conducive to giving the unit a work out.
    And the operation is totally noiseless and vibrationless, totally undetectable from inside while operating.
    Thanks for the inputs and recommendations!
    bburd
