TT Smart 60 drywell replacement
Drywell has failed. Not a flood, just enough water to make the temp sensor fail. I have an IBC boiler, so I am using an electronic temp sensor, not the original TT aquastat.
Here is the problem: I only have about 40" of clearance above the drywell, but the smart 60 drywell is 47". Is it worth trying to unscrew the drywell, reseal the threads, and reinstall? As if I replace it, I will need to completely disconnect and move the tank to gain needed clearance.
Second related question: Will a temp sensor work even if the drywell is wet? The new one I just got appears to have a pretty thick silicon seal where the wires come out of the top of it. The one that failed, the seal looked flimsier.
Thanks!
drywell?
Do you mean thermowell?
where is the well leaking? is it at the threads or is there a crack or porosity in the well itself? if it is leaking at the threads you should be able to reseal it with some teflon tape and dope or ball wicking or teflon cord or various potions if the threads aren't good quality
When you hit the ceiling at 40" above the tank, what is it made of? Is it drywall that connects to a space between the ceiling above ans the floor of the next level above the water heater? Is it the under side of that stair case that the bottom of the stair tread is visible? Is it the sub floor of the room above? Depending on what it is made of and what is on the other side there is this invention that I have from the early 1500s that I got from my great great great grandfather. this one is not as old as the original invention but a more modern style from 1700s.
There are even more sophisticated devices that use an electric motor to do the turning. I wonder if one of these might help to get that stick out of that tank?
One more reason I don't like those tanks. I know I've done it, but its probably been 25 years and I can't remember what I had for breakfast this morning. Weil McLain used re-badged TT tanks for years and their Series 2 shows a dry well repair kit (item 6). Maybe that could help?
Thanks HVACNUT, (NOW I know what he is talking about i.e. "drywell"). And for that ref. to replacement parts! Those TT tanks are good—a "tank in tank". Hard to drain. And that temp sensor has been problematic. NOTE: IF you do drain and refill the inner tank you have to do things in the right order, or you "can" collapse the inner tank.
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
