Indirect water heater
cm6230
cm6230 Posts: 22
Goodmorning guys,
What is everyone using for indirect water heaters that have a good warranty?
I’m dealing with an 80 gallon crown megastor with corrosion and pinholes on the relief tapping. All stainless steel, crown/ velocity says it isn’t under warranty because the homeowner isn’t the original owner and ownership was never transferred within a year from when the new owner bought the house.
I don’t do a lot of indirect heaters, looking for some advice on a good brand/warranty.
Thanks guys
    pecmsg Posts: 7,549
    You might want to get the water tested before replacing that heater and find the cause of the failure.
    Stainless steel is good but doesn't like salt and chlorine
  • GGross
    GGross Posts: 2,060
    you will find original owner as a stipulation for every one that I am aware of. I've used viessmann, triangle tube (now defunct but great while it lasted) HTP, NTI, amtrol. While they would have honored a warranty for the original owner almost certainly, pinholes and corrosion are typically not due to defects
  • cm6230
    cm6230 Posts: 22
    they’re on a well but have a softener and filter system. Water was tested last year. Everything came back clear. I think the original owners of the house didn’t keep up on changing the filters and softeners.
    hot_rod Posts: 28,343
    glass lined steel tanks tend to handle chlorides and salts better. Stone lined tanks from US Boiler and Vaughn are an option also.
    cm6230Larry Weingarten
    pecmsg Posts: 7,549
    Stainless Steel does not like salt!
    cm6230
  • cm6230
    cm6230 Posts: 22
    I was thinking the same thing, could it be salt from the softener?
    A lot of the brass fittings around the tank are corroded/white&crusty.
