Probe Type Low Water Cutoff LWCO Maintenance
This weeks video talks about the maintenance required for a probe type low water cutoff
Boiler Lessons
Ray… was this as low as you could go?🤗
I assume you mean ME, Paul.🙃
If the shoe fits, Ed! 😉
Nice video, @RayWohlfarth as always
It has a plastic spinner on the end. It keeps the probe clean with the spinning action
it moves with the water flow thru the pipes, not so good on a steamer.
Something I find interesting is all of the times Paul has said the Hartford loop doesn't save or protect anything.
If he's right that means the LWCO and proper maintenance are all that more important.
That's something that should be an easy sell in my opinion. I know I sleep good at night knowing my lwco works.
2 -
I liked the water chemistry comment at the end. A very good reminder for maintaining proper water chemistry. Thanks @RayWohlfarth
I have always said the LWCO is the real hero but the Hartford Loop gets all the credit (even when it doesn't prevent dry firing)
always good to be reminded of potential hazards if quality maintenance persons aren’t being utilized.
Thanks @Intplm. Water is very important
@JoeN51 The newer boilers need more miantenance than the older ones
Ray Wohlfarth
Boiler Lessons0 -
Most older boilers have a Mc D level control that must be blown off each week or month at least. If the McD fails due to mud in the bowl, the low water will catch the failure. If the low water fails as well, the boiler cooks. See it all the time. Proper monitoring and maintenance testing and cleaning will avoid a MAJORITY of boiler failures I observe.
John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.2
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
