Richardson
rohan_1794
rohan_1794 Member Posts: 17
I have a couple of these throughout my home, on the 1st and 2nd floor. The radiators get heat but quickly disapate.
Should these be replaced? I don't exactly know how these work. I have one in a bathroom that does not get heat at all, but I confirm heat is able to come from the inlet. We have a two pipe system.
20251228_150242.jpg 20251231_103359.jpg Screenshot_20260103_111716_Firefox.jpg 20251231_103404.jpg
    Jamie Hall Member Posts: 27,414
    There isn't much that can go wrong with those things… provided all the parts are still there.
    HOWEVER
    There is one thing that can go wrong: excess operating pressure. Anything over about 6 to 7 OUNCES per square inch is too much, and may prevent some radiators from heating.
    Two other possible reasons for a specific radiator not heating are that something is amiss with the trap elbow on the outlet side and it is unable to vent or drain — stuck closed — or that someone closed the inlet valve. Check the valve first… remembering that clockwise is closed.
    mattmia2 Member Posts: 16,925
    edited April 23
    or someone replaced the vapor valve on another radiator with a standard valve. or various knuckleheading at the boiler.
    Steamhead Member Posts: 18,545
    @rohan_1794 , where are you located? We might know someone who can help……..
    Consulting
  • rohan_1794
    @Steamhead I'm located in Bronx, NY.
    @JohnNY @EzzyT @clammy @Mad Dog_2 all work in NYC and a few others.
    Consulting
    If you want to figure it out yourself, we can help you with that too.
