Buffer tanks
So I have been buying John Wood tanks, and I really like them.
But I need 2- 400 gallon tanks, and Im limited on height. 3-300 wouldn't be good but Im limited on space. Anyone know of any other big steel tank manufacturers that would ship to VT, and have perhaps a 400 that is a little bigger in diameter, making it a little shorter?
Montpelier Vt
Amtrol goes to around 1000 gallons.
Do you need an ASME tank? My understanding is if your under 30psi (relief valve) you do not need ASME.
We needed a tank in a hurry once and used an air compressor tank. The tapings were not optimal, but we used double tapped bushings to reach across the tank.
I agree Highland would be a source.
There used to be hundreds of tank manufacturers but with the decline in oil many are gone.
I dont need to be insulated. I dont NEED ASME, but this is for wood boiler storage so it's nice because it's so big and typically entombed to not worry about having leaks later on. Not that it never happens but ASME typically are less prone. My ceiling is 94" and im very tight on space, so I need a tank that is 90" or so.
Tom
Montpelier Vt0 -
If you are looking for pressurized storage the modutank will not work.
The folks from Quick tanks make galvanized hydro pneumatic tanks up to 900 gallons in size
Manchester Tank builds tanks for LP and compressed air. They have vertical tanks under 90"., here is a 240 G. probably an expensive tank.
Can you mount a horizontal tank? Plenty of 300 and 500 LP tanks around>https://mantank.com/products/
these 75 psi galvanized tanks should work dimension is in the ballpark
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
