Buffer tanks
So I have been buying John Wood tanks, and I really like them. https://johnwood.com/wp-content/uploads/2014/03/JSTR.pdf
But I need 2- 400 gallon tanks, and Im limited on height. 3-300 wouldn't be good but Im limited on space. Anyone know of any other big steel tank manufacturers that would ship to VT, and have perhaps a 400 that is a little bigger in diameter, making it a little shorter?
Tom
Montpelier Vt
    hot_rod Posts: 28,526
    An insulated ASME listed tank?
    Mad Dog_2
  • leonz
    leonz Posts: 1,965
    Contact the Modutank people in Long Island city, New York.
    The sell tanks of all sizes that will be disassembled and you put them together
    and install a liner and a cover, I do not know if they offer insulation kits.
    www.modutank.com
    Mad Dog_2
    EBEBRATT-Ed Posts: 21,169
    Amtrol goes to around 1000 gallons.
    Do you need an ASME tank? My understanding is if your under 30psi (relief valve) you do not need ASME.
    We needed a tank in a hurry once and used an air compressor tank. The tapings were not optimal, but we used double tapped bushings to reach across the tank.
    I agree Highland would be a source.
    There used to be hundreds of tank manufacturers but with the decline in oil many are gone.
  • Tom_133
    Tom_133 Posts: 990
    I dont need to be insulated. I dont NEED ASME, but this is for wood boiler storage so it's nice because it's so big and typically entombed to not worry about having leaks later on. Not that it never happens but ASME typically are less prone. My ceiling is 94" and im very tight on space, so I need a tank that is 90" or so.
    Tom
    Montpelier Vt
  • leonz
    leonz Posts: 1,965
    If you are looking for pressurized storage the modutank will not work.
    The folks from Quick tanks make galvanized hydro pneumatic tanks up to 900 gallons in size
    Manchester Tank builds tanks for LP and compressed air. They have vertical tanks under 90"., here is a 240 G. probably an expensive tank.
    Can you mount a horizontal tank? Plenty of 300 and 500 LP tanks around>https://mantank.com/products/
  • Tom_133
    Tom_133 Posts: 990
    Dollar for dollar very difficult to beat the John Wood Company. They make great tanks, and at the right price. I guess we will have to try to figure out a different location at his house!
    Thanks for the help
    Tom
    Montpelier Vt
    GGross
    these 75 psi galvanized tanks should work dimension is in the ballpark
  • Tom_133
    Tom_133 Posts: 990
    I saw those but I want the tanks to run at 180, and if I read it right, they only go up to 140
    Tom
    Montpelier Vt
    GGross
