uncased horizontal coil needed
Does anyone know of a manufacturer that sells uncased horizontal evaporator? 410a, four ton.
Thanks to all
Any coil MFG can build a coil you need. Just Google "HVAC coil mfg".
Get a cased coil and remove it from the case. Is it an A coil, an H coil?
Whats there now?
thanks to all that responded, Currently there is a A coil that is in a case. The unit is in an attic where the opeing in the attic is not large enough to get a cased coil through. My thought was to get either an uncased or cased coil and remove it and install it in the existing case, and hopefully with the measurements it will make it through the attic. The existing one can come down in pieces, i would prefer not to butcher a new coil to get it through the attic opening. The existing coil is original so it was installed when the home was built, before the ceiling went in. Thanks to all
