Possible to remove sections from new radiator
orew
orew Member Posts: 2
edited April 10 in Strictly Steam
I might be able to get a brand-new castrads radiator for a good price, but it's a bit wider than I need. Would it be relatively easy to remove a few sections? If it's the reverse of their process to join sections for extra wide radiators, it doesn't seem too complicated.
I'd prefer to not buy their $250 tool kit if possible
    EdTheHeaterMan Member Posts: 12,254
    edited April 10
    You would need to ask the manufacturer whether that particular radiator comes from the factory as a fully assembled unit or if it is supplied as separate sections that are assembled at the job site.
    I do not believe there is an easy way to remove a single section from a new radiator once it has been factory assembled. Factory-assembled radiators are put together using section nipples and special assembly tools unlike the nipples you might use for putting two or three piece radiators together. Unless you can obtain those tools, it is very difficult to remove the nipples and separate the sections.
    The nipples used for field assembly are designed so the assembly tool can pass through each factory assembled section until it reaches the nipple that needs to be tightened to pull the separate sections together. Factory assemblies may use different nipples and tooling, which makes disassembly more difficult.
    Basically, the factory nipples and the assembly nipples are different.
    mattmia2 Member Posts: 16,877
    are they push nipple radiators held together with rods or radiators with left-right nipples?
    also note that if cost is your main factor, us boiler makes new radiators that are relatively inexpensive.
    you could also do things to limit the output of the radiator rather than shorten it if if you have the space
    Left right nipples. with a special tool to assemble larger rads that come is two or three pieces. The tool does may not work on the factory installed nipples. That is why I mentioned that you should call the manufacturer or email them.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,561
    It's a mistake to take apart a brand new, factory-assembled radiator over $250.00 bucks. Mad Dog
    Long Beach Ed
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    If it's only a couple of sections long and you can accommodate the width, keep it together and install a slower vent. You'll be fine. As Dog says, disassembly of a new one might be a crime.
    Mad Dog_2dabrakeman
