Chimney separating from House
topretailventure
topretailventure Posts: 1
edited November 2025 in Chimneys & Flues
We have an existing masonry fireplace that previously had a coal insert installed by the former owners. After removing the insert, we discovered several loose bricks inside the firebox, and we also noticed that the firebox is separated from the surrounding masonry by about 1.5 inches. We were planning to redo the masonry and install gas logs, but when the mason inspected it, he said the chimney is beginning to separate from the house. According to him, the chimney would need to be taken down and rebuilt if we want to install a vented gas-log system.
He also mentioned that there may be newer types of gas logs that can vent horizontally through an exterior wall rather than through a full-height chimney.
My questions are:
  1. Is there actually a gas-log or gas-fireplace system that can be vented directly out the wall, without needing a traditional chimney?
  2. If not, and the chimney does need to be completely rebuilt, do you have a rough idea of what such a project typically costs
    mattmia2 Posts: 17,994
    There are numerous systems that vent out the sidewall.
    If the chimney is separating that much there is probably a problem with the foundation under the chimney, it should all be one foundation with the house.
  • Here are about 20 to choose from https://www.woodlanddirect.com/direct-vent-fireplaces/
    See the vent directly behind the fireplace in this installation illustrtion?
    Jamie Hall Posts: 27,737
    Agree with @mattmia2 — if this is a reasonably modern house — concrete foundations — that much separation of a masonry chimney from the firebox indicates some real foundation problems (note that in a much older house, it doesn't). To be safe, the chimney — and firebox — will need to be taken down and rebuilt on a safe foundation. You ask pricing — we don't do pricing here, but it will be into the inexpensive new car range…
  • You ask pricing — we don't do pricing here, but it will be into the inexpensive new car range…
    And you don't even get to drive it out of the neighborhood. Only your neighbors will get to look at it.
  • dandub1960
    dandub1960 Posts: 54
    Most fireplaces are pretty bad as heating appliances. They're really more of an ambience thing. The side vents often are sealed combustion, so flames behind glass, negating a lot of the ambience add. On an open fireplace any power venting appliance (or even a chimney vented boiler) may reverse the flow in your fireplace flue. Even property assessors don't consider fireplace a valued accessory anymore. Maybe throw some candles and such in there and save your money for something else (smallish car?)
    Steward to 1923 Spanish revival near Chicago - 2 pipe steam 650 EDR shiny new Peerless 63-06
  • Poetek
    Poetek Posts: 1
    edited April 27
    I had my fireplace cleaned recently by the trusted chimney and fireplace experts in Fort Worth, and it made a big difference in how safely and smoothly everything runs. Their techs were straightforward, prices were clear, and the discounts helped a lot. Scheduling was easy too since they’re open most of the week. If you’re dealing with buildup or weird smells, they handled mine quickly and kept things stress-free.
  • psb75
    psb75 Posts: 1,162
    The chimney should already (originally) be separate from the house. If it is internal—not an outdoor, sidewall chimney—it should not be structurally attached to the house. It should be on its own foundation or share the main foundation of the house. If it's "verticality is being challenged" then you have real structural problems. Have a mason or a person with very good "structural eye" look at it.
