Damaged baseboard fins - Any way to bring back to life?
We are doing a bathroom renovation and I discovered some pretty good damage to the baseboard register fins. Are there any tools and/or tricks for straightening these out? I could just put the covers back on but I can't imagine these are operating at intended capacity.
Thanks
    EdTheHeaterMan Posts: 12,947
    I agree with Mat and Jamie on the amount of damage is not enough to worry about.
    However I might suggest that @WalnutFarmer is a man that is outstanding in his field!
    Intplm.
  • 4Johnpipe
    4Johnpipe Posts: 492
    You can find fin combs at some supply houses or online. This small amount wont make a noticeable difference though.
    LANGAN'S PLUMBING & HEATING LLC
    Considerate People, Considerate Service, Consider It Done!
    732-751-1560
    email: langansph@yahoo.com
    www.langansplumbing.com
    autosys1
  • guzzinerd
    guzzinerd Posts: 463
    Probably easier, and cheaper, to buy am air conditioning fin comb. They come with multiple sizes on a single comb.
    Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
    4Johnpipe
    i don't think any of them will be helpful for baseboard fins. maybe the one that is adjustable with the slide that adjusts the spacing
  • WillieJ
    WillieJ Posts: 17
    Over the last three years, I’ve done four bathroom remodels in my house, and the baseboard fins had similar damage in each one. I used a putty knife, a screwdriver and some patience to bend them back to a semblance of their original shape. They seem to work fine.
    mattmia2PeteA
    hot_rod Posts: 28,704
    needle nostril aka needle nose pliers can work
    If they are bent too much the metal stretches and will not reform completely
    If they get loose on the copper tube they don’t conduct as well either
