Recommendations
Thinking about purchasing this for sub 1300sf slab on grade home. Anyone have experience with this make?
Hello and welcome. I don’t have any experience with that brand. I’m sure it will operate fine when installed correctly with proper attention to air ducting and etc…
Depending on location and budget however I would reconsider your approach for that type of home. If you haven’t already poured you slab, I would suggest radiant hot water, ductless split heat pumps for your ac/shoulder season heating. Good luck!
THINK
That would have been my preference but there’s already 648 sf of concrete already as it was an existing apartment…
it never hurts to do a heat and cooling load calc. New tight homes can be in the teens for btu/ sq ft in the heating side
15 btu/ ft X 1300 sq ft is around a 20,000 btu/ hr load
Oversized equipment is one of the most common issues we see at HH.
Even worse on the cooling side where it may not run long enough to dehumidify. A cold, clammy home is no fun 🫣
500 Sq Ft per ton is old old school
a proper manual J room heat load loss must be done.
Then you need a manual D Duct design0 -
Much too large for the space, but the free gift is enticing.
