tankless water heater as a solar water heater backup
diyguy
diyguy Member Posts: 1
Trying to figure out how to use tankless water heater as a backup for Buderus 80 gal indirect water hater with 2 coils Any suggestions. ?
  • Ironman
    Ironman Member Posts: 7,903
    I’m assuming that the top coil is solar and the bottom connects to a boiler?
    If so, just pipe the tankless in series with the indirect’s hot line going into the tankless’ cold inlet.
    Set the indirect’s aquastat about 10* higher than the tankless.
    Bob Boan
    bjohnhy
