tankless water heater as a solar water heater backup
Trying to figure out how to use tankless water heater as a backup for Buderus 80 gal indirect water hater with 2 coils Any suggestions. ?
  • Ironman
    Ironman Posts: 7,978
    I’m assuming that the top coil is solar and the bottom connects to a boiler?
    If so, just pipe the tankless in series with the indirect’s hot line going into the tankless’ cold inlet.
    Set the indirect’s aquastat about 10* higher than the tankless.
    Bob Boan
    bjohnhydiyguy
  • diyguy
    diyguy Posts: 2
    There is no boiler I want to use Solar as main source -bottom coil And Tankless as axillary in top coil. I'm in SC
    hot_rod Posts: 28,776
    typically the solar is the pre heat to the tankless. Tankless in series on the potable side, not to the coil.
