"Carbon Dioxide/Monoxide Explosion" in Baltimore
Conflicting info from different news sources.
"Under Investigation"…………….
Consulting
unfortunately these types of accidents often will have reporting inaccuracies, the source is often ill informed, and the journalist is not an expert in the field either. For the curious the best you can hope for is that a CSB investigation is warranted. they publish very in depth reports and often will publish the report as an easily digestible youtube video.
CO2 tanks can run as high as 2,500#’s. could be something is simple as a fitting valve breaking
is this like the one where some tech claimed he was a hero for keeping a couple pounds of freon from escaping in to a large grocery store?
I think @EdTheHeaterMan was referring to the idea that Coca Cola once had a miniscule amount of cocaine in the product. According to my long deceased grandfather, it had a "kick" to it. I suppose today they use caffeine instead.
One just has more oxygen.
And then there's CO3.
CO₃ Molecule is very unstable and quickly reacts to form other compounds.
Kind of like @ChrisJ very unstable.🤣🤣🤣
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
