Connection between boiler flue and power venter is not sealed.
Ravi
Ravi Member Posts: 3
I recently got a gas boiler with power venter installed. Boiler model is Crown - AWR140ENSZ2PSU and Power venter is Field control SWG 6S. This newly installed system feels really loud from the day it was installed. I noticed that the connection between flue pipe and the vent from power venter does not appear to be sealed. Is this supposed to be open like in the picture? I believe this unsealed portion is the major reason for the excessive noise. I am also concerned if this could be hazardous.
WhatsApp Image 2026-02-24 at 13.28.04.jpeg WhatsApp Image 2026-02-24 at 13.28.04 (1).jpeg WhatsApp Image 2026-02-24 at 13.28.04 (2).jpeg
  • Grallert
    Grallert Member Posts: 1,152
    That is normal for an atmospheric boiler. Power venters are often loud put there could be other issues if it is "Too loud" Hw is the venter installed?
  • Ravi
    Thank you for responding. Venter is installed on the side of the house, about 3ft above the boiler. Can the opening be sealed? I would appreciate any tips to reduce this noise that has been driving the family crazy.
    pecmsg Member Posts: 7,379
    No, you can't seal it. Why was a power venter installed?
  • Ravi
    I was told that PV was needed due to sidewall venting.
    Can we get a picture of outside?
