Preheating boiler feed water
any pros and cons on preheating boiler feed water prior to adding feed water to the system?
Burnham Independence IN-4 steam
the pro is you can remove virtually all of the dissolved oxygen in the water by heating it to boiling
The con is the time and energy spent
I boil mine
I usually do a gallon or so in a pot
Here is a story about using a low cost steam boiler for food grade process steam. It goes into a detail about preheating water that goes into a steam boiler. There is good reason to do it.
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
