stubborn rad vent removal
I replaced these about twenty years ago, the ancient ones unscrewed with a firm handshake, the Gortons I put in with teflon tape, but they aint budging. i was thinking a hair dryer to warm up the stem first, but what can i use for a little more leverage? maybe wrap a towel around it?
thnks B
If you're just using your hand, that isn't going to work unless you are The Hulk.Try an 18" pipe wrench, you don't need heat and certainly not from a hair dryer.See below!!!!
haha you are right I was thinking it was a #1 main vent
these being angled Gortons in the radiators, ill assume a light tension on the main body with visegrips will do? or Channel lock pliers on the round of the body?
I actually have used a pipe wrench parallel with the vent body to grip the round part. The tiny 1/8" fitting gives way before crushing the vent (much)
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 50 Industry Classes
