stubborn rad vent removal
I replaced these about twenty years ago, the ancient ones unscrewed with a firm handshake, the Gortons I put in with teflon tape, but they aint budging. i was thinking a hair dryer to warm up the stem first, but what can i use for a little more leverage? maybe wrap a towel around it?
thnks B
    ethicalpaul Posts: 9,076
    edited February 4
    If you're just using your hand, that isn't going to work unless you are The Hulk.
    Try an 18" pipe wrench, you don't need heat and certainly not from a hair dryer.
    See below!!!!
    yobyllib
  • STEAM DOCTOR
    STEAM DOCTOR Posts: 2,680
    18" wrench might be Overkill. And will probably crush the vents. Pair of pliers should do the trick
    ethicalpaulyobyllib
    haha you are right I was thinking it was a #1 main vent
  • Intplm.
    Intplm. Posts: 3,162
    @yobyllib When and if the threads brake off in the radiator use a 1/8" tap to tap out threads while also removing the broken piece inside. Start with a strong "handshake" as you put it, and move on to the appropriate tools as needed.
  • yobyllib
    yobyllib Posts: 4
    these being angled Gortons in the radiators, ill assume a light tension on the main body with visegrips will do? or Channel lock pliers on the round of the body?
    I actually have used a pipe wrench parallel with the vent body to grip the round part. The tiny 1/8" fitting gives way before crushing the vent (much)
